Old 25-03-14, 09:13 PM   #11
DJ123
DJ123's Avatar
Default Re: Pointy won't start after datatool S4 removal
What about the 4 wires which are the factory fit alarm connector?
BMW F800ST
Old 25-03-14, 09:14 PM   #12
Mikey360
Can't find them, i think they've been removed?
Old 25-03-14, 09:20 PM   #13
DJ123
DJ123's Avatar
They run into a 4 way connector (similar to the fault code block). Should be in the same loom on the left hand (looking towards the front of the bike) side of the bike (rear panel)
BMW F800ST
Old 25-03-14, 09:27 PM   #14
Mikey360
Is it a small square whitish connector with mostly black cables that run to the indicators???
Old 25-03-14, 09:37 PM   #15
DJ123
DJ123's Avatar
They are in 1, there's more
BMW F800ST
Old 25-03-14, 10:30 PM   #16
Mikey360
Right, pics for clarity now!
So, this is the 3 to one orange and green wire splicing that doesn't appear to be standard.
The left orange and green cable comes from the fuse box, splits into three (that's where it looks dodgy) and one goes to the resistor, the other two look as if they go towards the front of the bike?
This is where part of the alarm wiring had been spliced in, its the Mode select switch connector. I've connected it temp (before soldering) and still no digital display or fuel pump. (look at orange and green wire)
Is this the Alarm connector? One of the wires had been chopped into the alarm wiring. This one is position on the LHS behind the battery in line with the rest of the loom
This is a similar box, in the same place but level with the battery, don't think this one was spliced into.
Or is this the alarm connector?
Old 29-03-14, 01:00 PM   #17
muzikill
muzikill's Avatar
Really, a colour wiring diagram will support your fault finding. Its difficult doing it this way over the internet without someone being present to go through all the colours.
Sent from my GT-I9505 using Tapatalk
Datatool alarm removal thedonal SV Talk, Tuning & Tweaking 54 24-07-15 06:34 AM
Datatool 3 Removal? Chris199 Bikes - Talk & Issues 0 15-02-13 11:49 PM
datatool 3 removal? Gibby Bikes - Talk & Issues 16 20-06-12 10:59 AM
Removed Datatool 3 now won't start. Ghosd10 SV Talk, Tuning & Tweaking 4 22-02-11 01:58 PM
Datatool System 3 removal. Lozzo SV Talk, Tuning & Tweaking 17 14-05-07 09:42 PM
