30-12-04, 05:30 PM | #1 |
Motrax LED Indicators
Just fitted a pair of these on the front - much sleeker and brighter than the originals.
Took about an hour to fit both (including soldering in different resistors to correct the flash rate - 10 watt 10 ohm resistors less than 50p each from Maplins). Photos below:-
2000 - 2004 SV650S 2004 - 2009 SV1000S 2009 - 2013 Triumph Sprint ST1050 2013 - 2016 Triumph Explorer 1200 2016 - Ducati Multistrada DVT S |
30-12-04, 06:12 PM | #2 |
Sorry but they look pants
30-12-04, 07:11 PM | #3 |
Pants as in Johnny Vegas'big baggy cream & brown Y fronts, or one of kylie's skimpy lace thongs?
30-12-04, 07:18 PM | #4 |
Matt. Did you get the resistor packs with them? I did raise the fact with motrax, that they where not strong enough, and i eneded up using 2 packs on each indicator. But i would have to agree that they are very bright.
30-12-04, 07:21 PM | #5 |
They came with resistors, however they were no good when I tried them(couldn't see what resistance the originals were). Luckily I had bought some from Maplins just in case - picked up a couple of spares for when I do the back - will wait till I get a Hamicad before I fit the rear ones
30-12-04, 09:34 PM | #6 |
Motrax are 're-issuing' thier LED indicators in the New Year with stronger resistors which should stop the flash rate problem.
Apparently it's a problem with some bikes but not others, but they're upping the resistors to cope with everything... hopefully. Which is why I've put off buying mine for a few weeks. I'd prefer oval ones (to go with my [bike's] lovely curves) but they only do LED 'arrows'. Much brighter though, which is why I'm fitting them. |
31-12-04, 02:12 AM | #7 |
Hey,
Are you using both the LED Motrax side indicators aswell as the LED 'sidelights' by the headlights as turn signals? If so, I wouldn't mind some help on how you went about wiring that. I am super stupid when it comes to wiring and ohms and resistors... Mitch
2003 Suzuki SV650S Silver
Keep your feet on the pegs and keep your right hand cranked. Did your right hand write a cheque that your rear tire couldn't cash? www.MITCHCAVE.com | I Do It With Twins |
31-12-04, 12:30 PM | #8 | |
I endured the same problem when converting number-plate and sidelight (at front) to LED. 1.5v in LED terms is a lot given high output LEDS run at 4-4.5v. |
Motrax Diamond Indicators | Baph | Ancillaries | 1 | 18-06-07 09:23 AM |
Motrax indicators - new | Girth | For Sale - SV's and SV related items | 1 | 04-06-07 11:51 AM |
Motrax LED Indicators | Fizzy Fish | For Sale - SV's and SV related items | 6 | 26-03-07 12:23 PM |
plee for help......motrax led indicators | jaymz | The Essex Lounge | 7 | 01-05-06 01:45 AM |
MOTRAX L.E.D indicators | stumpy1 | Ancillaries | 2 | 16-03-05 07:15 PM |
