Old 02-01-16, 02:31 PM   #621
Nutsinatin
Nutsinatin's Avatar
Default Re: What have you tinkered with today?
Took the shock linkage out, cleaned and repacked the bearings, much better now!
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 04-01-16, 09:50 PM   #622
RPM
Found a bit of a fuel leak, which may or may not now be OK. Could have been a dodgy connection at the petcock which I cut back and refitted. If not then hell knows.
Found a bit of oil in the airbox, which may or may not now be OK. Have a feeling the previous owner may have overfilled on oil. There wasn't a huge amount, and it was very clean. However, the breather pipes deffo have a wet look around the connectors to the airbox. Engine doesn't feel or sound like the rings or valves are in trouble…hmmm
Old 05-01-16, 12:15 PM   #623
ophic
ophic's Avatar
You can get a bit of oil in the airbox through the breather tube. It has a sponge over the port to minimize it.
Silver SV650SK3, Fuel exhaust
Old 05-01-16, 08:43 PM   #624
RPM
Maybe I need to clean the sponge and then keep an eye on things
Old 05-01-16, 10:38 PM   #625
TheWeeSteev
Replaced my standard windscreen with a black double bubble, which for some reason proved to be way more fiddly than I anticipated.
I also received a Tutoro chain oiler but won't be able to fit that until the weekend, not with my skills
Old 07-01-16, 08:10 PM   #626
gibbzy2k1
Fitted new spark plugs and cleaned the drain as it was running on one cylinder since the floods. Hopefully a fender extender next week.
Also replaced the crap 45w headlight bulbs with proper 60/55w bulbs.
Also found axel stands work well instead of a paddock stand and downpipes get very hot. ��
Old 08-01-16, 10:49 AM   #627
TheWeeSteev
What bulbs did you use? I'm wanting to switch mine over for these dark days and wasn't sure what to go for.
Old 08-01-16, 12:02 PM   #628
gibbzy2k1
I went for these as they were in stock and buy one get one free.
http://www.halfords.com/webapp/wcs/s...&storeId=10001
Sent from my D5503 using Tapatalk
Old 08-01-16, 02:44 PM   #629
Corny Gizmo
I and a few others use these, really bright, nice crisp white light. A lot better than standard.
Clicky
Old 08-01-16, 02:52 PM   #630
gibbzy2k1
I've used them in the car. I used Halfords this time as I could pick them up same day. And their BOGOF offer made them almost the same price.
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
