Old 04-10-17, 11:36 PM   #1
SixFiddy
Default Gen 2 SV650 clock/nose fairing mounting point bent.
To get straight to the point, the part on the front of the frame that sticks out which has 2 holes/threads for the clock/speedo bracket to be bolted on to is bent after a recent off. I only noticed after replacing the insanely bent bracket and nose fairing. It looks like it's bent about 10 degrees to the left.
Does anybody know how malleable that part is? When I replace my cracked headlights I might have a go at repositioning it if it's possible...
Thanks in advance!
Old 05-10-17, 12:07 AM   #2
Default Re: Gen 2 SV650 clock/nose fairing mounting point bent.
i have straightened one but i used to be a blacksmith and i can tell you its a RPITA. requires heat and a big sturdy well bolted down vice and big stillsons/bar.
Old 05-10-17, 12:11 AM   #3
SixFiddy
Thanks for that - Sounds like that requires the frame to be free... Well I don't plan on ever selling this bike so it looks like it'll I'll have to live with that until the bike's demise.
Old 05-10-17, 05:44 AM   #4
Chris_SVS
Chris_SVS's Avatar
PITA to fix, I just replaced mine
Chris_SVS is offline   Reply With Quote
Old 05-10-17, 08:07 AM   #5
Stilo
Stilo's Avatar
http://www.ebay.co.uk/itm/SUZUKI-SV-...oAAOSwjk9ZTsBc
Cheap enough
He was a hairy handed Gent who ran amok in Kent Awhooo
Stilo is offline   Reply With Quote
Old 05-10-17, 05:37 PM   #6
SixFiddy
Wasn't referring to the bracket, but the actual mounting point on the frame
Old 06-10-17, 06:17 AM   #7
Stilo
Stilo's Avatar
OK good luck with fixing that, if that is bent is the rest of the frame straight?
Old 06-10-17, 02:08 PM   #8
SixFiddy
"I hope so". I haven't checked properly but I've done a couple hundred miles since my last off and it rides okay
Old 08-10-17, 12:21 PM   #9
i haven't straightened a headstock lobe and i would not even attempt it and if i did i would cut it off and weld it back on or send the frame off to a motoliner.
Track fairing & seat unit wanted for point sv650 sv robbo Stuff Wanted 0 20-09-17 08:14 PM
Sv650 front nose fairing pointy 1812_S Stuff Wanted 1 08-07-16 02:51 PM
SK5 - Mid Engine Mounting Bolt bent! robbie09 SV Talk, Tuning & Tweaking 5 22-02-12 10:08 AM
Nose Fairing and Tank- K5 SV650 (YC2) JT1306 Stuff Wanted 5 13-09-11 04:06 PM
My pretty nose is all bent timwilky Idle Banter 66 03-07-09 07:54 AM
