24-02-17, 03:31 PM | #51 |
Re: Anyonen had a stuck oil filter recently?
that article is from 1994
24-02-17, 04:07 PM | #52 |
24-02-17, 06:03 PM | #53 | |
Interesting, particularly ..
However I guess nobody wants to risk trashing their engine, so for me the not too overpriced motorcycle specific oil makes sense. |
24-02-17, 06:19 PM | #54 |
Oils have come a long way since 1994.
Motorcycle oils are a cross between engine and gearbox oils, gearbox duty puts high shear loads on molecules and the friction modifiers in some car oils can cause clutch problems in bikes. Like aesmith I will stick with bike specific oil. here is a quote from an oil article I read - they can't even agree about car oils, let alone bike specific oils. 'Because of the real or perceived need for motor oils with unique qualities, many modern European cars will demand a specific OEM-only oil standard. As a result, they may make no reference at all to API standards, nor SAE viscosity grades. They may also make no primary reference to the ACEA standards, with the exception of being able to use a "lesser" ACEA grade oil for "emergency top-up", though this usually has strict limits, often up to a maximum of litre of non-OEM oil. Harley Davidson may have at least partially hopped onto this bandwagon....'
2016 SV650 AL7 Courage is resistance to fear, mastery of fear, not absence of fear - Mark Twain Last edited by SV650rules; 24-02-17 at 10:45 PM. |
24-02-17, 07:03 PM | #55 |
Jeez man, please edit that post and change the colour! My eyes - arrrrrgh!
24-02-17, 07:39 PM | #56 | |
Interesting read, confirms much of what many people suspect however the bottom line is you make your choice and need to be happy with that. Personally I was a bit chuffed when I read the article because I've been running all my four stroke bikes with the exception of my 1960 Matchless on Mobile1 fully synthetic for as long as I can remember. My Hornet is currently sitting on just under 70k, doesn't burn a drop between services, and I've never had to touch the valve train. My SV has around 20k on it, all of which have been pretty much flat out as it doesn't get ridden any other way.... same story as the Hornet. Oh and they are both still on their original clutches. |
24-02-17, 07:41 PM | #57 | |
24-02-17, 08:36 PM | #58 |
Opie oils do Castrol Power 1 4T fully synth 4litre for £32 with free shipping UK mainland, for me that is cheap enough.
24-02-17, 10:59 PM | #59 |
double post
24-02-17, 11:00 PM | #60 |
Nah.When I've used up me Motul I'll be buying this<BFG>
http://www.ebay.co.uk/itm/20L-Semi-S...IAAOSwNSxVcXAL Last edited by R1ffR4ff; 24-02-17 at 11:02 PM. |
Haven't been on here recently. | Felix_ | Photos | 10 | 03-08-12 09:39 PM |
What U-turns have you done recently? | Nobbylad | Idle Banter | 13 | 27-10-11 07:37 PM |
Done anything silly recently? | Jayneflakes | Photos | 16 | 18-09-11 07:49 AM |
Hobby - have you taken one up recently? | Miss Alpinestarhero | Idle Banter | 55 | 09-07-09 05:24 PM |
Not been recently. | REEVESIE | Soho Massive | 2 | 02-12-05 12:05 AM |
