Old 09-09-19, 09:48 PM   #11
netsurfer
Default Re: Slight misfire after 10 year layup
Cheers for the tip!
Pulled the carbs tonight, both screws at approx. 2+1/4 turns
I took the bowls off and think there was a very small blockage in one of the small jets. (larger ones were clear, they are marked 140)
However, when I put the carbs back on the bike is off a cylinder
Guess I'll be taking them off again tomorrow night! Must be a stuck float needle as symptoms would suggest no fuel getting to the rear cylinder.
Was really hoping this was going to be the last time, even went as far as putting a vacuum hose on the front carb throat for balancing them (it's blocked up for now)
Originally Posted by R1ffR4ff View Post
Just to add.I've removed the central Horn bracket and moved my Horn to the Front left of my SV.This means I can get to my Front Spark plug without having to drain the coolant by just removing the 3 rad bolts and pushing the Rad forward
netsurfer is offline   Reply With Quote
Old 11-09-19, 05:04 PM   #12
netsurfer
Panic over, the temporary fuel tank I was using had a blocked breather
Misfire is now gone, running as sweet as a new one
Now the brakes and MOT!
Old 11-09-19, 05:06 PM   #13
R1ffR4ff
R1ffR4ff's Avatar
Great news
Slight fib from Jaguar embee Idle Banter 2 19-12-15 09:10 AM
Slight leakage.....exhaust Amplimator SV Talk, Tuning & Tweaking 6 20-12-08 04:25 PM
So I had a slight bump! KnightRider Thames Valley 42 31-07-08 06:01 PM
Little problem, high tickover & slight misfire Mike2165 SV Talk, Tuning & Tweaking 5 30-08-07 07:14 AM
Slight Concern... Z MitchC SV Talk, Tuning & Tweaking 11 16-04-05 06:33 AM
