27-07-17, 03:32 PM | #11 |
Re: curvy yoke conversion help
27-07-17, 03:35 PM | #12 |
That looks like the top yoke off a Suzuki Bandit.
That's definitely not for an SV650....you just found the issue.
Nemo me impune lacessit. Last edited by 21QUEST; 27-07-17 at 03:36 PM. |
27-07-17, 03:35 PM | #13 |
that looks like a bandit top yoke but i could be wrong
27-07-17, 03:35 PM | #14 |
27-07-17, 03:36 PM | #15 |
Ffs was advertised as sv650 top yoke. Will have to send it back. Thanks v much for your help
27-07-17, 03:38 PM | #16 |
Where are you based?
27-07-17, 03:44 PM | #17 |
Radcliffe, near manchester
27-07-17, 04:00 PM | #18 |
Ah, the part of the country where folks appear less miserable.
I have the correct top yoke. I'd PM you later...got finger fatigue at the minute from typing on the phone. |
27-07-17, 04:15 PM | #19 |
It's because we're usually drunk
Thank you but I've just nabbed the right one from eBay so think I'm sorted (assuming they are sending the right one this time) |
27-07-17, 07:18 PM | #20 |
You can't use the N throttle cable on the S housing - its completely different. You can use the clutch cable, but don't need to. Both cables can be rerouted perfectly well to give the extra length needed, as long as the new bars are not too high or wide. You will need to use longer brake hoses/hose. You will also need to cut the screen to clear the bars on full lock.
The N bottom yoke is slightly different, but you don't need to fit it. You will need to use thick washers (approx 4mm) on top of the yoke/under the nut, otherwise the nut will bottom out. The N bottom yoke has a shorter stem, I think due to the N top yoke being thinner overall. The S top yoke has a spacer cast into the bottom of it to make it thicker overall, I suspect to raise the S bars slightly. I did find fitting the yoke to the forks was tighter than the one I took off, but I think that was due to manufacturing tolerances, and it did fit with a bit of effort. You could drill the S top yoke, and fit risers, an ally plate glued underneath apparently works well. The N yokes can be hard to come by, or overpriced. It took a while to find mine for £30, with the bottom yoke which I didn't use. Doing the conversion was the best thing I ever did to my curvy S, it is really comfy now, well worth the effort and relatively small cost. Last edited by andy650; 27-07-17 at 07:26 PM. |
ABM top yoke conversion? Curvy. | Aligowers | SV Talk, Tuning & Tweaking | 11 | 24-08-14 07:24 PM |
Curvy stuff, yoke, clutch cable, spark plugs, handlebar conversion | RenegadeMaster | For Sale - SV's and SV related items | 0 | 22-05-12 10:15 PM |
faired curvy SV top yoke conversion guide? | sicknote | SV Talk, Tuning & Tweaking | 4 | 05-03-12 09:29 PM |
Tope Yoke Conversion? | Hogzi | SV Talk, Tuning & Tweaking | 8 | 19-03-06 10:01 PM |
Top yoke conversion | Grinch | SV Talk, Tuning & Tweaking | 14 | 26-07-05 07:40 PM |
