The Teacer
A CD has got stuck in the console in my car and now the whole thing is frozen. The whole console is stuck in the tilt out position and the worst thing is the radio's stuck on Radio 1! HELP ME please someone I can't stand any more of that innane drivel
It's a 58 Yaris SR, with the TomTom in the console tilting thingy! And I've tried sticky tweezers in to no avail. Please???
There's a fine line between a hobby and a mental illness |
Ask Toyota .its still under 5year warranty?
Otherwise disconnect the -ve battery terminal for 1hr.
Raisin cookies that look like chocolate chip cookies are the reason I have trust issues. |
The Teacer
Thanks.
Not sure if it had a 5 year warranty - will check that out As for the battery suggestion - I have the mechanical skill of a chimp with learning difficulties so I'll save that one for later ![]()
Pop into your local dealer regardless of Warranty - if there is a quick fix, they will know and probably not charge to help you out.
Or, if its like any other CD player, get a paper-clip/long needle and look for the little (1mm across) manual eject hole and use the paperclip/needle to push the CD player open.
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
Would you like to borrow my blonde wig? Then just flutter eyelashes.
Tender is the day, The demons go away, Lord I need to find, Someone who can heal my mind... |
Turn it off and sing to yourself instead.
The Teacer
My singing is even worse than Radio1!
Looks like its the dealer and eyelashes then. Can't do that til sat at the earliest though - arghh!
Radio one is walk.
#9 |
Toyota only started the 5 year warranty on cars registered after 1st July 2010
#10 |
Well Nissan does have a good will policy.
If Toyota is as good they will look.
Look what I got stuck.... | BanditPat | Idle Banter | 30 | 28-10-09 11:31 AM |
Scamera van stuck | deejay77 | Photos | 11 | 14-04-09 05:50 PM |
Bolts on Reg/Rec stuck | Colby | SV Talk, Tuning & Tweaking | 13 | 04-02-08 04:42 PM |
brakes stuck on ?? | leemole | SV Talk, Tuning & Tweaking | 4 | 06-01-08 07:29 PM |
something stuck? | Stingo | Idle Banter | 2 | 30-05-06 04:32 PM |
