12-04-13, 03:48 PM | #1 |
SV650s K7 pointy - jerkiness and poor idle
Hi all,
I'm a complete newbie to the forum and SV owners clan after buying my first SV650s K7 on Saturday. Sadly already a couple of problems. I have 2 issues which may or may not be related - I've done some digging around the forum but can't find any threads where both issues are present. Bike specifics - 2007, scorpion can, otherwise standard, 48k miles. issue 1 - jerkiness at low revs. I got the bike from a garage and they said it's a little jerky but they couldn't find anything causing it. It seems to be at about 4000-5000 rpm when at constant speed (never under acceleration) where it jerks intermittently. Looking at threads this could be TPS but then I also have the second issue... issue 2 - once the engine is warm the idle is erratic, it drops from around 1200 to 900, constantly up and down. Occasionally it stalls and won't start again unless I give it a bit of throttle, but if i let go off the throttle it will instantly die. It takes a few times to get it going again. The idle is fine and constant on cold start and revs high until warm and then settles nicely after 10-20 seconds. I'm not sure if the two issues are related or if they are seperate but it's annoying the hell out of me. I want to avoid taking the bike back to the garage to check it over if it's simple fix, or I can at least rule out a couple of things before hand as I need my bike to ride to work. Any suggests from the trusty SV riders? Thanks, |
12-04-13, 05:34 PM | #2 |
Re: SV650s K7 pointy - jerkiness and poor idle
It's got to be worth a try adjusting the TPS, that's a cost free process if you've got a T25 security bit (I didn't so it cost me £1.85).
12-04-13, 06:18 PM | #3 |
yeah i'll definitely give that a go over the weekend.
is that likely to be causing problems with the idle though? |
12-04-13, 06:33 PM | #4 |
I don't claim to be an expert on the SVs, but when I adjusted my TPS it certainly made the idle erratic when I moved it too far. I was also thinking that trying the adjustment might help you see if the sensor is behaving as it should.
12-04-13, 10:30 PM | #5 |
I'm trying to pick up as much information on my SV as possible.
So could somebody please humour me ... What's TPS? |
12-04-13, 10:33 PM | #6 |
Therapeutic Penis Stimulator
12-04-13, 10:34 PM | #7 |
Second for trying the tps(throttle position sensor), otherwise sounds like potentially a carb issue? Was the bike sat for long before you bought it?
12-04-13, 11:17 PM | #8 |
13-04-13, 12:01 AM | #9 |
i would check the TPS, Battery connections/condition and air/vacuum hoses. the hoses usually throw up an FI light on the dash.
other things to check, oil level, spark plugs and air filter. |
13-04-13, 03:14 PM | #10 |
Throttle balance first, then TPS.
Fairly common symptoms of unbalanced intake - and easy to check.
What should an SV650S 2000 Idle at? | YellowMonkeyBoy | SV Talk, Tuning & Tweaking | 13 | 23-03-11 09:34 PM |
Poor idle and occasional cut out | Jay Tee | Bikes - Talk & Issues | 2 | 07-11-09 01:58 PM |
Poor cold starting on a pointy | flymo | SV Talk, Tuning & Tweaking | 1 | 28-03-09 10:03 AM |
Poor pointy brakes | Miles | SV Talk, Tuning & Tweaking | 22 | 16-03-09 08:07 AM |
Fabbri double bubble screen - poor fit on my K3 pointy!? | SilverfoxUK | Bodywork | 4 | 04-06-06 08:37 PM |
