Old 27-08-17, 10:27 AM   #1
DomP
Default Rear spring weight
Just looked on ktech to calculate a spring rate for my 142lbs without gear, it came up with 6.8kg/mm which sounds incredibly low. Not even sure I could find a stock replacement from a gsxr or zxr that would be that low?
Sent from my SM-G903F using Tapatalk
Black 2010 SV650S Fully faired
White 2011 YZF R125 sold
DomP is offline   Reply With Quote
Old 28-08-17, 12:56 PM   #2
Default Re: Rear spring weight
my advice is keep saving for a proper shock.
Old 28-08-17, 07:54 PM   #3
DomP
Yeah I know I should but having hacked the toolbox I'm now desperate to do some modding
Old 28-08-17, 08:09 PM   #4
some good news i suppose is if you can change out the spring on the new shock and its the same size as the SV one then the SV one is perfect for your weight. only problem is you will have to demolish the SV shock to get the spring off.
Old 28-08-17, 08:10 PM   #5
DomP
Hey now there's an idea! How self serviceable is a zx6r shock then?
Old 28-08-17, 10:12 PM   #6
you would need to have a look and see if the spring seat is removable. if it is its just a case of winding the collars up and removing the spring seat, change the spring out and put the spring seat back in.
Old 29-08-17, 01:49 PM   #7
johnnyrod
johnnyrod's Avatar
Am 99% sure my Ohlins has a 9.0kg spring. I'm about 10 stone, I was told it was good for up to about 15 stone of rider.
Old 29-08-17, 04:57 PM   #8
DomP
Is that not quite a heavy spring for 10st, everything I've read suggests no more than 8.0 for my weight. Having watched some youtube vidoes I'm tempted to buy a second hand zxr shock of the right length and service it using my spring like Lance suggested.
Old 29-08-17, 05:31 PM   #9
a 9.0kg spring is waaaaay to heavy for a 10st rider it should be around 7.0.
unlike front springs there is a greater range of rear springs, the reason for this is to match rider weight better.
easy way to tell is set the static sag to around 7-10mm then jump on and see how much it compresses. your looking for a total of around 35-38mm drop for road use. if its under the 35 then the shock wont be working within its proper stroke and topping out too easily.
a pointy SV rear will hop and skip and slide all over the place with too heavy a spring as the linkage rate is around 1.8-1 which means that for every 18mm the wheel rises the shock shaft only moves 10mm, unlike the curvy which is a 1-1. so adding too heavy a spring will not allow the shock shaft to work properly and not allow the valving to do its job.
Old 29-08-17, 08:23 PM   #10
johnnyrod
johnnyrod's Avatar
Will check tomorrow. The SV's linkage has more leverage than e.g. GSXR
Ohlins shock spring rates by rider weight ads109 SV Talk, Tuning & Tweaking 16 15-09-12 11:14 PM
spring weight help pencil shavings SV Talk, Tuning & Tweaking 3 02-03-12 10:26 AM
rear spring and weight questions. WP shock DaveW_42 SV Talk, Tuning & Tweaking 8 10-08-10 03:35 PM
Suspension question regarding shock spring and weight monkey Bikes - Talk & Issues 6 27-05-10 01:44 AM
Spring Rate and Oil Weight? PURPLE SV Talk, Tuning & Tweaking 4 25-05-09 07:43 PM
