Hello all,
Further stripping down of my SV for track only. I am going to build a custom bracket for tach, oil, temp, fuel and nuetral lights. Everything else goes away. Wondering if the ignition is routed through the head chip for rev-limiting, and what other issues may come up. I can probably get the oil, temp and neutral lights going without too much work. I see some diodes in the schematic - will figure that out. The fuel gauge may be a 3 wire situation - I don't know. Anyone tackle this already? Any hints? Thanks, Denis |
The haynes manual has a full wiring diagram. As far as I'm aware the instrument pod is purely for display and does not actively affect the bike. It should run without it (I may be wrong on this).
The rev limiter is built into the ignition control unit.
The Sick Man
Ive run my bike on track without any thing past the front part of the loom, it ran totaly fine. Only things that it still had was all the switch gear connected.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
Right, right. I ran it withhout head chip (everything pulled off of front except hand control connectors). The rev limiter worked fine. Temp, nuetral, oil lights are easy. The low fuel light runs through the head chip PC board - I probably will not bother with a work-around on that. Tach and idiot lights going into the section that used to hold speedo. The old tach section is sawed off now. The problem was that the tach was vunerable in a get-off. Also I drilled and threaded for 6mm steering limit adjuster bolts into the lower triple clamp.
Thanks for replies / help. Denis |
Project Track day bike | duffbattye | Track Days | 0 | 23-05-08 03:04 PM |
Used tach needed | jschritz | Stuff Wanted | 0 | 31-03-06 06:29 AM |
Speedo dead but tach working | Avtjr64 | SV Talk, Tuning & Tweaking | 2 | 26-07-05 03:35 PM |
Jumpy tach, possible fix | dnwhoop02 | SV Talk, Tuning & Tweaking | 2 | 11-04-05 08:06 PM |
tach bulb number | toyozuki | SV Talk, Tuning & Tweaking | 3 | 26-10-04 01:59 PM |
