14-08-09, 11:44 AM | #1 |
Carb Balancing
Hello.
Not an SV to start off with but an in-line 4 Honda. I need to balance the carbs and the fuel line might not be long enough for me to use the tank. I have some fuel hose but what should I use to hold a bit of fuel in whilst I balance it? Do I need to look out for anything like too much fuel going through due to no vacuum operated tap? Cheers in advance Rob |
14-08-09, 03:23 PM | #2 |
Re: Carb Balancing
The fuel flow should be fine as the carbs have float valves to prevent overfilling. I would just use a longer bit of hose and keep teh tank and vacuum tap in the setup.
Carb balancing | Grinch | Soho Massive | 10 | 07-05-09 07:44 AM |
Carb balancing. | scottjames | SV Talk, Tuning & Tweaking | 12 | 27-10-08 01:14 PM |
carb balancing | ricky | SELKENT | 6 | 22-04-08 08:11 AM |
carb balancing | Banus | SV Talk, Tuning & Tweaking | 9 | 23-02-06 01:38 PM |
carb balancing | johndo | SV Talk, Tuning & Tweaking | 3 | 08-04-05 05:31 PM |
