09-04-17, 05:10 PM | #1 |
Curvy can't get first gear
Evening all,
My friend has an early curvy which he is re commissioning after winter, but can't get first gear at all! Has anyone experienced this before? Did try a search but couldn't see anything similar Cheers Mike
It should be remembered that there needs to be an element of challenge to a "short cut," otherwise it would just be "the way" |
09-04-17, 07:52 PM | #2 |
Re: Curvy can't get first gear
When you say 'can't get', do you mean it grinds? The clutch pack has probably stuck solid over winter plus the lifting mechanism may need replacing or at least correctly adjusting to maximise lift. There are threads on this forum to help you do that.
If that isn't what you mean, please expand on can't get a bit. |
10-04-17, 05:48 AM | #3 |
No first gear at all, gets all the rest just fine,
10-04-17, 08:39 AM | #4 |
First check to do with selection problems is to ensure the gear lever is moving properly on its pivot on the footrest.These corrode and get sticky leading to erratic action(can I say that on here).Try a bit of oil on it first,then dismantle it and free it properly if that seems to be the issue.
11-04-17, 07:31 AM | #5 |
These gearboxes are normally reliable if not abused.
OK, lets try this: 1/ When you press the lever down, does it feel normal? 2/ Does it select first if the engine is off so you don't rely on the clutch at all? 3/ When you change down from the higher gears does it feel normal? 4/ Is the bike able to be ridden, if it is, what happens if you try to change to first while it is rolling? Try to give more detail about what is actually happening or people will not be able to help. |
11-04-17, 08:08 AM | #6 |
From what he has told me.
All ok at beginning of ride Unable to get 1st after a couple of miles, no warning or noise Not been able to get 1st ever since All feel and sounds normal just no 1st all other gears and neutral ok Will ask him to let me have a go and report back
11-04-17, 12:20 PM | #7 |
Sounds like its just the drag of a poorly adjusted clutch to me. It needs everything slackening off along the cables, then adjusted at the gearbox end for 1/8th of a turn. Then remove any cable slack with the adjuster near the gearbox end of the cable. The adjuster at the clutch lever is the past point of adjustment. One of the Gurus on here has it written up well. I'lll see if I can find it.
11-04-17, 12:23 PM | #8 | |
Here ya go! That needs to be right before looking elsewhere.
12-04-17, 10:30 AM | #9 |
Hence my questions 2/ and 4/.
16-05-17, 11:17 AM | #10 |
Did your friend resolve this?
Sent from my SM-G935F using Tapatalk |
Gear lever for Curvy. | rivsm | Stuff Wanted | 3 | 30-08-13 12:30 AM |
Curvy RH switch gear | Flash B | Stuff Wanted | 4 | 27-02-11 04:51 PM |
Curvy gear linkage rod | Old Git | SV Talk, Tuning & Tweaking | 5 | 01-03-10 09:49 PM |
Gear changer for curvy SV | buell | Stuff Wanted | 1 | 28-08-06 10:17 PM |
Gear lever for a curvy | Andy13_uk | Stuff Wanted | 3 | 05-02-06 12:28 AM |
