10-05-09, 02:08 PM | #1 |
pre loaded adjusters & springs - curvy
i have pre laoded adjusters on my bike. but my forks are really soft even if i have the adjusters all the way down or all the way up. i take it if the adjusters are all the way down the forks get harder if they are all the way up they get softer ?
seeing as my adjusters seem to make no diffrent what are the bets springs and adjusters that you can buy ? or that people have found good to use
Curvy With Lots Of Bits ...
But Still More To Come |
10-05-09, 02:32 PM | #2 |
Re: pre loaded adjusters & springs - curvy
the adjusters are for preload only, it is the springs which determine the stiffness of the suspension
10-05-09, 03:35 PM | #3 |
The adjusters work fine when you have springs of the correct weight. Contact a suspension firm to see about getting some which are a higher rate than standard as well as a heavier weight oil.
10-05-09, 04:13 PM | #4 |
get the right springs for your weight, maybe a thicker oil to help damp things and then decide where to spend money, cartridge emulators or a GSXR front.
SV suspension is very basic, you live with the compromise or pay to get decent suspension
Not Grumpy, opinionated. |
10-05-09, 04:29 PM | #5 |
try a change of fork oil. just out 15w in my pointy. and makes such a differance. not a hard job either. give that a go before "forking" out on new springs!!!
10-05-09, 06:37 PM | #6 |
so springs for my weight and thicker fork oil should make them stiffer ?? any good companys out there that people have used for springs.
10-05-09, 06:38 PM | #7 |
How loaded up is your Bike... | Grinch | Photos | 30 | 14-09-08 12:48 PM |
What do i need to convert the 1999 (no preload adjusters) to having preload adjusters and progressive springs. | sv_rider1990 | SV Talk, Tuning & Tweaking | 12 | 11-07-08 05:15 PM |
KTECH springs and K2+ preload adjusters | carsounds_dan | For Sale - SV's and SV related items | 2 | 02-07-08 10:23 PM |
Curvy Preload Adjusters | Stevetmanchester | Stuff Wanted | 0 | 14-05-08 08:28 AM |
Fork preload adjusters on a curvy? | Berlin | SV Talk, Tuning & Tweaking | 12 | 06-09-07 08:00 AM |
