Idle Banter For non SV and non bike related chat (and the odd bit of humour - but if any post isn't suitable it'll get deleted real quick). There's also a "U" rating so please respect this. Newbies can also say "hello" here too. |
27-10-16, 10:09 AM | #1 |
Car heater, too hot or too cold
The heater on my BMW 320D E91 doesn't get hot unless you put it on the highest 28 degree setting which is then too hot.
Anyone have any ideas what could be wrong?
2015 GS 1200 Adventure |
27-10-16, 08:14 PM | #2 |
Re: Car heater, too hot or too cold
What year is that, at a guess your thermostats have failed
28-10-16, 07:54 AM | #3 |
It's 2010, if the thermostat had failed I'd expect it not be be getting hot at all.
28-10-16, 03:00 PM | #4 |
No, I think they work on the principle of max heat until ambient temp (indicated by thermostat) hits the required value. But the highest setting just ignores the thermostat and pumps out max heat permanently.
Silver SV650SK3, Fuel exhaust |
28-10-16, 05:41 PM | #5 |
Could be worth checking the cabin filter. Fixed the issues I had the heating and cooling performance on my car.
They do rely on an air flow to perform properly and the engine temperature Sent from my D2303 using Tapatalk
02-11-16, 04:40 PM | #6 |
Had the car serviced last month and they replaced the cabin filter then. I pulled it out anyway and had a look and it does look pretty new.
I've also been monitoring the coolant temperature using ter Torque app on my phone and a Bluetooth OBD adapter. It's sat a a constant 80-85c.
03-11-16, 07:38 AM | #7 |
Could be the thingy that takes the heat from the coolant to your heater is gummed up. Can't remember what its called, but a mate had a similar problem on another car.
03-11-16, 09:30 AM | #8 |
How accurate is the outside air temperature sensor?
They don't just give a nice little display for the driver, but also determine whether any hearing or cooling is needed for the cabin (and also determine fuel air ratio for the engine amongst other things) Sent from my iPhone using Tapatalk |
03-11-16, 10:58 AM | #9 |
Heater matrix?
03-11-16, 11:07 AM | #10 |
It'll not start blowing in anger until the heater is significantly hotter than the current inside car temp. Prior to that it will blow but not hard. Around the heater control area you'll find a little (about the size of a micro SD card) grill with a fan behind it. This is where it samples the cabin temp. When mine was clogged with fluff it went a bit weird so give that a clean out.
My old BMW had a heatsink controller for the fan motor. This failed and then the fan was either off or very very on. This was a right bugger to get to but once swapped out all worked fine. Not sure if the newer BMWs still have these or where they live. BMW forums refer to these as Hedgehogs. Oh and also on the 5-series you set target cabin temp with one control but can also set the dash vents to blow hot and/or cold regardless of the cabin temp. May be worth checking you've not got the dash vents set to cool while trying to lift the cabin by 15degrees.
Don't want to be the quickest; don't want to be the best; just want to be the one having the most fun. XL125Varadero -> Curvy SV650N-Y -> SV1000N-K3 -> Multistrada 1200s Twin-tastic stuff. Minister for Sustainability Aliquid prudentissimus delectabiles et intelligentes in adamasset lingua. Last edited by Mark_h; 03-11-16 at 11:13 AM. |
Carb heater question | sprocket | SV Talk, Tuning & Tweaking | 14 | 13-06-18 01:58 PM |
Is this patio heater any good? | Ed | Idle Banter | 9 | 14-03-11 08:35 AM |
Recommend Me... A Garage Heater | squirrel_hunter | Idle Banter | 27 | 21-11-09 09:48 PM |
Carb heater | Jase22 | Stuff Wanted | 0 | 01-11-06 06:05 PM |
Underbike heater ? | Gforceuk | Bikes - Talk & Issues | 15 | 23-11-04 08:56 AM |
