Old 02-04-16, 10:23 PM   #761
tom_e
Default Re: What have you tinkered with today?
Changed all my engine bolts with a chewy ss kit and replaced a few other random bolts with ss ones.
Cleaned and lubed everything around my rear brake pedal as it was sticking down after use, moves nice and smoothly now.
Sent from my XT1580 using Tapatalk
tom_e is offline   Reply With Quote
Old 03-04-16, 07:32 AM   #762
mister c
mister c's Avatar
This Just finished making brackets to fit my Nonfango panniers.
Old 03-04-16, 10:05 AM   #763
muzikill
muzikill's Avatar
Dropped the oil, Cleaned and rebuilt the starter motor and removed the rear brake master cylinder for a rebuild.
Old 03-04-16, 02:47 PM   #764
vysie
Just removed my tax disk holder and ordering some proper cleaning kit to do a proper deep clean
Old 03-04-16, 03:35 PM   #765
admin
John T
admin's Avatar
I had a good look at the chain and sprockets on Stu's KTM. Definitely in need of a change so got him to book it in. He never cleans the chain, or seemed aware the sprockets were well past their best.
Good call. Never neglect the chain. I've just seen some photos on the VFR forum of a damaged engine caused by a broken chain. I had a chain break on my moped when I was 16, it whiplashed the generator cover smashing that, belted the flywheel and bent the crank.
Old 04-04-16, 11:41 AM   #766
BoltonSte
Mostly put the street back together. New exhaust studs, rust stripped/repainted worn sheathing sorted on cables.
I can now get the tank on/off in record time for me, I also discovered that it's a good idea to block the intake before putting the front subframe on or you may drop a nut which then goes into the airbox which means the tank comes off...again.
Had an SV or three.
Street triple R - gone but not forgotten.
Now trying the lunacy that is KTM with a Superduke GT. for the pillion capability of course.
BoltonSte is offline   Reply With Quote
Old 09-04-16, 07:20 PM   #767
yokohama
Another job I wish I'd never started. I wanted to put my new shock on and while in there, thought I'd take a look at the linkage.
I don't think this has been touched since the bike was born, 12 years and 23,000 miles ago.
It meant an afternoon with degreaser and Autosol.
A little scored around the edges but the parts that engage with the needle bearings are ok. Can I get away with these?
I'm going to have to replace the washers on the front bearing and a couple of the nuts.
The needle bearings themselves cleaned up nicely and are all intact and still moving.
Old 09-04-16, 07:28 PM   #768
I would change the lot now
It's worth it in the long run
Sent from my E2303 using Tapatalk
Old 09-04-16, 07:45 PM   #769
yokohama
Old 11-04-16, 11:35 AM   #770
Nobbylad
Nobbylad's Avatar
Put new Armstrong wavy discs and SBS HH sintered pads on the Gixer, stripped and cleaned the calipers, bled the brakes.
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
