03-04-18, 04:34 PM | #1 |
What wrong? Don’t think it is getting fuel?
Hey guys/girls
I need your help! I can’t get my sv650s k5 to start. I have had it in storage for 2 years, because my economy didn’t allow it. The battery was dead so I changed it, and I also changed the fuses. The display says check but there is no humming from the fuel pump when I turn the key. What could be the reason why the fuel pump isn’t pumping? Sent from my iPhone using Tapatalk |
03-04-18, 04:54 PM | #2 | |
Junior Member
Re: What wrong? Don’t think it is getting fuel?
Sent from my SM-G900V using Tapatalk |
03-04-18, 05:02 PM | #3 |
No it cant`t be that, because the starter cranks the engine.
Is it NOT possible to upload a video? |
03-04-18, 07:25 PM | #4 | |
04-04-18, 08:13 AM | #5 |
I'd lift the tank and take the Air Filter cover off and spray some Carb/Brake cleaner into the intakes whilst cranking to see if you can get it to fire up.
Then if you can get it to fire up put at least half a 250ml Bottle of Redex Fuel treatment or similar into the tank,so long as it's got plenty of fuel in there and give the engine a good run.Then it will need a general good service. With the bike having been stood so long I would also put aside an evening or Afternoon and pull apart every electrical connector(Especially the Main Stator Connector near the R/R) and check and remove corrosion and treat with Switch cleaner and then ACF50, http://www.acf-50.co.uk/motorcycle.htm I do this to all my Motorcycles. HTH
"Stultus est sicut stultus facit" Last edited by R1ffR4ff; 04-04-18 at 08:18 AM. |
Thread Tools | |
WTD, curvy fuel tap and fuel level sensor | northwind | Stuff Wanted | 3 | 06-12-17 12:33 PM |
Fuel rant whinge moans hate fuel prices bah | Daimo | Idle Banter | 54 | 18-02-11 11:02 PM |
Where is the fuel? Lifted fuel tank. | BoomBoomBox | Bikes - Talk & Issues | 72 | 07-12-10 01:01 PM |
When wearing high heels was wrong, so wrong... | Razor | Idle Banter | 6 | 03-06-06 08:51 AM |
Wrong Construction wrong colour . | amarko5 | Bodywork | 12 | 30-10-04 03:23 PM |
