Old 14-03-17, 10:15 PM   #1
Jayneflakes
Jayneflakes's Avatar
Default The green connector again!
My K3 burned out the green ignition connector block some time ago and I replaced it with a bigger unit from an ATV. I thought that using a connector with bigger blades would mean that it was safe from further issues, but alas this was not the case.
The replacement connector also burned out and the cause was some corrosion of the terminal. I had used a water proof shield to protect the connector, but all it did was keep the water in and speed up the corrosion.
I have now replaced it for the second time and my precious Sylvie is back to her usual reliable self.
Happy days
Jayne you're a Pussy Magnet
Old 15-03-17, 07:56 AM   #2
Geodude
Geodude's Avatar
Default Re: The green connector again!
D'oh! bet you said a few naughty words well its fixed (again) so yay
Old 15-03-17, 08:45 AM   #3
R1ffR4ff
R1ffR4ff's Avatar
I treat all my electrical connectors with ACF50,
Check out this thread,
http://forums.sv650.org/showthread.p...ighlight=acf50
6 posts down.
Old 15-03-17, 10:59 PM   #4
Jayneflakes
You know me so well! I may have expressed a few Effs, Bee and even a couple of Cees! Happy days.
6 posts down.
I have used ACF50 for a long time now, the protective cover I had fitted prevented the spray getting in, but seemed to allow water to seep in over time. I am almost ready to wash off the winter filth and the thick coat of ACF I sprayed on last year.
Old 16-03-17, 08:11 AM   #5
R1ffR4ff
R1ffR4ff's Avatar
Take the extra bit of time to pull the sockets apart and then spray the blades and sockets.Much more effective.
Also is it possible the protective cover is doing more harm than good?Maybe holding in moisture that otherwise would evaporate away?
Once you have ACF50'd the connector you could smear some dialectic grease over it?
http://www.ebay.co.uk/itm/Dielectric...kAAOSwxH1UFN2R
HTH
Old 22-03-17, 11:58 AM   #6
Jayneflakes
HTH
Absolutely, the waterproof cover did exactly this and acted as a water trap, so it has been removed.
Thanks for the tip on the grease too.
Old 22-03-17, 08:36 PM   #7
Exuptoy
The manufacturers of ACF-50 also make Corrosion Block. Just pop apart the connector and place a line of the dielectric grease along the crimp and reassemble.
https://www.ebay.co.uk/itm/391632649660
Green connector replacement questions crisis SV Talk, Tuning & Tweaking 4 11-04-14 09:25 PM
Pointy complete electrical failure - green connector problem? Glandwr SV Talk, Tuning & Tweaking 34 05-11-13 04:55 PM
Where to buy this connector? djotanov SV Talk, Tuning & Tweaking 6 22-11-11 09:02 PM
HM Racing in green street green hall13uk SELKENT 4 16-06-05 04:25 PM
The Rose and Crown Green Street Green Orpington Kent sexysi The Good The Bad and The Ugly Pub and Cafe guide 4 17-06-04 09:14 AM
