Old 24-03-17, 09:14 AM   #11
Fen Tiger
Default Re: Coolant leak?
But a guard would not have stopped the horn falling off into the back of the radiator. Going to check the fixing on my horn bracket is done up. Thank you for the heads up.
Fen Tiger is offline   Reply With Quote
Old 24-03-17, 09:36 AM   #12
SV650rules
A radiator guard and fender extender are two of the first things I fitted to my AL7 from new as I have seen problems caused by stones before, even on cars where radiator is much better protected.
2016 SV650 AL7
Old 24-03-17, 12:29 PM   #13
TicklinJock
TicklinJock's Avatar
I think the 2003/2004 radiator is wider, so it might be called 2005-on.
TicklinJock is offline   Reply With Quote
Old 24-03-17, 12:34 PM   #14
HanksW7
Junior Member
HanksW7's Avatar
I bought this one.
https://www.ebay.co.uk/itm/122305704104
Installation pics to follow.
HanksW7 is offline   Reply With Quote
Old 24-03-17, 01:02 PM   #15
R1ffR4ff
R1ffR4ff's Avatar
Originally Posted by HanksW7 View Post
I bought this one.
Looks good to me.Hope all goes well
Old 24-03-17, 03:21 PM   #16
Sorry to thread-jack, but I've got a coolant leak too. It has completely emptied itself so I need to fill it up to find the leak. I don't really want to use coolant for this because I'm probably going to have to drain the system once I find the problem.
Would this de-ionised battery water be ok for this? Linky
Old 24-03-17, 03:40 PM   #17
HanksW7
Junior Member
HanksW7's Avatar
I am no seasoned pro but having researched this extensively over the last couple of days I would say if you're flushing the coolant system, and you're only filling it to find the leak then using plain water will be fine.
When you're changing the coolant you use water to wash the system out so I would use water to find the leak. Fix whatever needs fixing, then flush again and fill with the appropriate coolant after it's fixed. Or you're just wasting de-ionised water.
Old 24-03-17, 03:51 PM   #18
tom_e
Yep fine, that's what I used to flush mine through last time I changed my coolant.
tom_e is offline   Reply With Quote
Old 24-03-17, 04:14 PM   #19
Biker Biggles
Biker Biggles's Avatar
Ordinary tap water is fine as long as the temp is above freeezing.Race bikes use water as standard and dont seem to have any issues although they get drained when stored.Long term corrosion is prevented by inhibitors in coolant.
Old 24-03-17, 04:27 PM   #20
tom_e
I was always led to believe that you don't use tap water in your cooling system as the minerals in it can block the cooling channels like limescale in your kettle.
Coolant leak Dinglespeed SV Talk, Tuning & Tweaking 6 30-04-12 01:41 AM
Coolant Leak Chalky SV Talk, Tuning & Tweaking 7 21-05-11 11:05 AM
Coolant Leak slloyd Bikes - Talk & Issues 9 21-09-10 10:30 PM
coolant leak SimJ SV Talk, Tuning & Tweaking 0 02-05-07 11:05 PM
Coolant leak LHS Tex SV Talk, Tuning & Tweaking 0 13-05-05 01:51 AM
