23-01-08, 02:54 PM | #1 |
Fitting hot grips - bike won't start!
Hi,
I've started fitting oxford hot grips to my curvy. Got the bar ends removed with a bit of hassle (bolts were solid) and got the old grips off no problem. I then tried a dry run by putting the grips on without glue and connecting to battery. I tried starting the bike but nothing happened. There is power in the battery (~12.45V) and all lights etc come on. When I hit the starter button nothing happens, no noises or anything. Any idea what could cause this? Cheers Ali |
23-01-08, 02:57 PM | #2 |
Re: Fitting hot grips - bike won't start!
kill switch?
23-01-08, 02:59 PM | #3 |
I only wish it was something as stupid as that - good try though!
23-01-08, 03:11 PM | #4 |
Reckon you may have disturbed the clutch switch on the LHS clipon,
Check that and try again... |
23-01-08, 03:12 PM | #5 |
When you come to wire them in properly make sure you use a relay, one that will only power them up with the bike is on/running.
23-01-08, 03:15 PM | #6 |
23-01-08, 03:54 PM | #7 |
Tried messing about with everything but nothing seemed to be loose. I then got it off the side stand, kicked it out of neutral then back in and it started fine. Reckon the neutral or sidestand switch are a wee bit dodgy but that'll be a job for a nicer day. It's been blowing a gale and pouring it down the whole time I've been out there.
With regards to fitting a relay I decided not to bother as I got the new model of oxford grips that switch off when the battery gets below ~12.7V. The hot grips now work. Tested them and they started heating up, hopefully they'll get a tad hotter when I'm out and about. I need to find somewhere that sells heat shrink sleeving for the connections now as I don't fancy leaving the connections open to the elements. Any recommendations? Cheers for all the input folks! |
23-01-08, 03:59 PM | #8 |
are you sure it was not in gear the 1st time?
23-01-08, 04:02 PM | #9 |
23-01-08, 06:11 PM | #10 |
Maplins for heatshrink
'52 Curvy S | So good.....it made me want to trump! If at first you don't succeed - use more gaffa tape. |
fitting grips | AndyBrad | SV Talk, Tuning & Tweaking | 25 | 15-02-09 08:12 PM |
Fitting new grips | RPC_SV | Bikes - Talk & Issues | 4 | 27-07-08 08:05 PM |
Fitting Hot Grips! | Jackie_Black | SV Talk, Tuning & Tweaking | 14 | 18-02-08 02:12 PM |
fitting hot grips | hovis | SV Talk, Tuning & Tweaking | 59 | 16-01-07 01:40 PM |
Fitting Heated Grips | Grinch | SV Talk, Tuning & Tweaking | 12 | 14-03-06 09:30 AM |
