14-03-07, 08:51 PM | #1 |
high mileage?
the sv i am looking at buying will only be my 2nd big bikea and i was wondering what is considered HIGH mileage on say an 04 650?
my r6 had 22k on it and was fine just wondered what the suzuki v-twin is good for? |
14-03-07, 08:53 PM | #2 |
Re: high mileage?
Mine is 7 or 8 months old now. I have 15k on the clock. I bought it brand new.
Whatever the milage, make sure it has a service history! You can usually set your watch by my service schedule! (you might be 200miles late for work if you did, but you get the point!) |
14-03-07, 10:36 PM | #3 |
Re: high mileage?
theres some real big high milers on this site! me not being one of them
14-03-07, 10:38 PM | #4 |
Re: high mileage?
my 53 SV1000's has racked up 38,000 miles with no problems to speak of
15-03-07, 12:21 AM | #5 |
Re: high mileage?
I got 130,000+ trouble free miles , after that, no serious troubles but noticable increase in oil consumption
compression test @ 135k service revealed 230psi compression rear cylinder and 90psi for the front. subsequent engine teardown revealed valve guides worn beyond service limits (consistent with oil consumption, only smoked a bit on startup), one exaust valve in front was not seating properly due to valveguide, pistons & rings were not worn beyond service limits but worn enuf to warrant replacement crank, rods & bearings all ok, but cam chains worn beyond service limits, so case will need to be split for rebuild anyway, bike was 100% dealer serviced, per chart in owners manual, no more, no less this bike was used as an adventure bike, at least 40,000 miles of total were gravel roads & fire trails, prolly a couple thousand miles of single track dirtbike trail, stanting on pegs slipping clutch in 1st &2nd gear, maybe 15,000 miles or so of divided highway and the rest, rural & secondary roads, less than 500 miles of urban riding original clutch lasted 102k, at that time only fibre plates & springs were changed, still has original steel plates voltage regulator/rectifer was replaced 2 times, nothng else except normal oil changes, tuneups etc. valve clearance only needed adjustment 2 times forts time @ 75k, second time @ 120k YMMV |
15-03-07, 02:09 AM | #6 |
Re: high mileage?
good to hear i will be looking for many more years of riding on my bike
15-03-07, 08:25 AM | #7 |
Re: high mileage?
My K5 is gonna be 2 yeas old at the end of june and has done 27,000 miles so far. It's never let me down once, I had a new chain and sprocket at about 20,000 miles, serviced it, put tyres on it and fueled it up and thats it.
15-03-07, 08:31 AM | #8 |
Re: high mileage?
50k on omy k1
15-03-07, 08:33 AM | #9 | |
Re: high mileage?
I only ever get about 130 miles between fuel fill-ups. I'm impressed! |
Thread Tools | |
High mileage | markbatten | SV Talk, Tuning & Tweaking | 24 | 28-08-08 08:57 PM |
High mileage and Engine smoke, what to do? | Mags | SV Talk, Tuning & Tweaking | 17 | 27-11-06 07:58 PM |
High Mileage, is it a problem | daza | SV Talk, Tuning & Tweaking | 23 | 17-05-06 04:52 PM |
What is High Mileage on a bike? | aimhamilton | Bikes - Talk & Issues | 30 | 25-07-05 10:18 PM |
High mileage | andyrs | SV Talk, Tuning & Tweaking | 5 | 01-04-05 04:46 PM |
