28-03-08, 01:35 PM | #11 | |
Re: Anti-Pinch Pin
Let us know how you get on with the pin thingy, pics and all Matt |
28-03-08, 05:09 PM | #12 |
Re: Anti-Pinch Pin
I take it you just slide these through the frame to give you somewhere to chain a big chain to other than the wheels? I presume it doesn't stay in place when you're actually riding the bike?
28-03-08, 09:44 PM | #13 |
Re: Anti-Pinch Pin
That's the one! I'm going to look at my new bike before I buy one, not sure if it fits yet.
05-08-08, 08:50 AM | #14 |
Re: Anti-Pinch Pin
Has anyone used one of these on a pointy? I am giving very serious thought to buying one, but can't see any reference being made to SVs on the site.
05-08-08, 09:10 AM | #15 |
Re: Anti-Pinch Pin
how strong is the pin?
as its no good having a 200quid chain if the bolt can be cut in a few mins? |
05-08-08, 10:49 AM | #16 |
Re: Anti-Pinch Pin
Good point hovis. Would like to see some sort or testing on it similar to what Almax show you. (that vid is what made me buy an Almax chain)
05-08-08, 11:01 AM | #17 |
Re: Anti-Pinch Pin
Ceri JC there is a fella by the name of GordonM on here that has one, he recommended it to me see 'Rate My Security' Thread he is using it on a K8 pointy through the frame underneath the tank. Dont know what length tho maybge he'll see this and enlighten us with more info.
05-08-08, 03:16 PM | #18 | |
Re: Anti-Pinch Pin
Having said that I haven't tried it. Btw if the Almax links only just fit in a bolt cropper (from the videos I've seen) you're unlikely to be able to fit the pin itself in a bolt cropper. |
05-08-08, 10:32 PM | #19 |
Re: Anti-Pinch Pin
It was this thread that I first learned about the anti-pinch pin and made me join sv650.org, thanks gettin2dizzy
I bought the 490 mm long Anti-pinch pin which seems fine, the ends of chain fit on comfortably without pressing against the fairing. I put the pin through the small triangular hole in the frame under the tank. I have to be careful to avoid some wires and pipes though. There's a pipe which I think is the coolant going into the rear cylinder of the engine that can't be totally avoided. The pin is partly resting on this and partly resting on the frame at the right hand side of the bike. I have my chain through my ground anchor and coming up each side of the bike to the pin, then padlocked with the Squire SS65CS padlock. My chain is an Almax Series IV 19mm chain. The ground anchor is a Colossus concrete-in type flush with the ground. It works great and I feel my bike is much safer now than when I just had a chain through the back wheel. Though I know anything can be destroyed with the right equipment. Photo time.... This is the hole in the frame where I put the pin. The bit of light you see above the hose is where I put the pin. When the bike is tilted to the left on the side stand, the frame at the right takes part of the weight of the pin and chain. Chained to ground anchor: 2 metre chain, 3 links unused. I had to cut slits in the cover at the 4th link to allow the pin to pass through. This makes the chain tight around the ground anchor and onto the pin. Err, I hope no one is still on dialup with all these images. |
28-05-09, 01:26 PM | #20 |
Re: Anti-Pinch Pin
can some one tell me where to get this pinch pin for a sv650n K6 i have the ALMAX 19mm IV as well 2meter
cheers Last edited by hindle8907; 28-05-09 at 01:55 PM. |
Yoke pinch bolt torque? | Ruthja2801 | SV Talk, Tuning & Tweaking | 11 | 08-03-09 10:03 PM |
New Titanium Front Axle Pinch Bolts | Michael S | For Sale - SV's and SV related items | 2 | 02-08-07 08:52 AM |
recent terrorist threats... pinch of salt. | Richie | Idle Banter | 5 | 16-07-07 08:12 PM |
Pinch me twice - Fork leg | Blue_SV650S | SV Talk, Tuning & Tweaking | 5 | 08-11-06 04:46 PM |
Anti British and anti American threads - crass and boring | Ed | Idle Banter | 40 | 13-06-06 06:08 PM |
