The Sick Man
I am following the haynes manual to check the valve clearances on my bike.
I did the front as per the book saying that the lobes should point away from each other and got some intresting things. My intake and exhaust are off. They are under the specified amount. I was getting readings of .05 for the intakes and .10 for the exhaust. Now the rear became odd. I did not matter that the alignment was on R the lobes would never point away from eachother like on the front cylinder. They would point up. Is this normal? The piston is at the top of its stroke though and the valves are all closed. I also got readings similer to the front. Seems like the shims are too big on my bike. Would this be because the valves are worn down? Im not putting the bike back together in case the shims do need to be changed. <table border="1"><tr><td></td><td colspan="2" align="center">Front</td><td colspan="2" align="center">Rear</td></tr><tr align="center"><td></td><td>Exhaust</td><td>Intake</td><td>Intake</td><td>Exhaust</td></tr><tr align="center"><td>Right</td><td>0.15</td><td>0.10</td><td>0.10</td><td>0.15</td></tr><tr align="center"><td>Left</td><td>0.15</td><td>0.10</td><td>0.10</td><td>0.15</td></tr></table>
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
Basically most folks think valves "loosen" since in the old days, they did, so the general though is that they loosen. The old tappet with a nut and screw could back out or get worn, which increased clearance. Now with your SV you have a shim riding on a valve stem under a "bucket" that the cam rides on. In this arrangement they generally tighten as the valve and seat wear. Usually the first adjustment or two will be all you need, and from then on it is usually a check, but we are talking 30,000 miles.
I hope this helps, it might be in Texan, so may sound odd.......... |
Are you sure you've got the cams in the right spot?
I'd forget about the marks on the crank and just turn the engine until the cam lobe in question is pointing away from the bucket completely, check it then. Anywhere, (in reason), on the base circle will be fine, and - if you have - you wouldn't be the first to get them confused. I think you have my number, call me if in doubt.
The Sick Man
Ok, yep they were pointing away from the bucket, phew.
Ok From thoes values above it looks like the exhaust shims need to be changed. Is it far enough out that its now damaging the engine. From what i thought, if the value is less than specified the valves are wearing into the head and therefore the need to change the shims is vital. I was just thinking about it. Not sure if its correct though.
#5 | |
Having been a car mechanic for several years I came across this many times. Remove the air filter and you should hear a smooth sucking noise. If combustion is getting past the inlet valve it sounds more like an exhaust! Howver it is usually quite bad by the point you can actually hear it. I can't advise you about tolerances of the SV650 engine, but I can warn you about the dangers of not doing anything. Kind regards Tim |
hi TSM,
you're right about the clearance getting tighter with age. you're also right about the difference between the checking position of the lobes on the front cylinder and those on the back: on one cylinder, the cam lobes should point outwards , while on the other they should point inwards, i don't know which cylinder is which. It's all in the manual though. I got confused the first time too. i used to look at the peep hole for the F/T and R/T marks, but now, i do it just by sight, i just make sure the lobes are perfectly symmetrical placed (when you look to the engine head) and check 'em like that. Normally, there's also some marks on the cam gears which should align with the cylinder head. and for these engines there's a basic rule: too loose is better than too tight, so change those shims ![]() |
#7 | |
The Sick Man
How many miles has your SV done?
My K3 has knocked up 30,000 miles and I was going to take it in to have this specifically done since routine stuff like oil, air and brakes I do myself. Bloke on the phone was surprised, said he hadn't seen a K3 with more then 15,000 on it and couldn't say if it was likely to definetly need new shims. Apparently it'd be £120 to check the clearances and more if they need sorting. I'm reluctant to tackle this myself as I have no garage/drive and don't want to risk foreign bodies getting inside the engine. Anyone here definetly had to have the shims changed? What mileage was this done? |
#9 |
The Sick Man
K2 has had a hard life, 21k.
I still dont have a definate answer on changing the shims, so the bike is still in peices.
#10 | |
Assuming that the measurements you have made are correct, I'd be changing all of the shims, the inlet clearance is 0.1mm minimum, which all of yours are at, in the circumstances I'd open them one shim so that they're somewhere near the middle of their allowable range, this means that it'll likley be the longest period 'til they need changing again. However, all of your measurements are suspiciously round numbers, and your bike has only 20,000 on it, it is unusual to say the least that there would need to be much adjustment needed at that small mileage, note I say unusual - not impossible. Therefore I think you need to get a second opinion before doing anything more.
Valve clearances - how do you know? | SUPERSTARDJ01 | Bikes - Talk & Issues | 19 | 09-05-09 05:16 PM |
Valve Clearances | pmapp | SV Talk, Tuning & Tweaking | 6 | 23-01-09 01:28 PM |
Valve clearances - K3 | Lozzo | SV Talk, Tuning & Tweaking | 1 | 24-07-08 09:24 AM |
Valve Clearances | DanAbnormal | Bikes - Talk & Issues | 31 | 07-02-08 06:22 PM |
Doing the valve clearances... | instigator | SV Talk, Tuning & Tweaking | 7 | 16-10-06 10:08 PM |
