Old 26-08-19, 03:52 PM   #71
admin
John T
admin's Avatar
Default Re: First world problems and bike dilemas
Originally Posted by Adam Ef View Post
Rear tyre was an MOT advisory (2 years ago) and is very flatted off. The front looked ok, but he didn't check inflation and he has it standing in a shed at his mother's house and only starts it every few months. It's had 7 miles put on it since the last MOT two years ago? Bad idea?
They have pretty robust engines and can withstand long periods of inactivity. Weak points are ccts, which seem to fail at the 30k+ mark, mine have been replaced. Also stator regulator failure. I've had no problems with mine and I'm now at 37k. Opinion seems to suggest that excess heat kills the stator as owners in warmer climates seem to suffer most.
Sent from my Moto G (5) using Tapatalk
Old 26-08-19, 07:19 PM   #72
SV650rules
My brother fitted 12volt computer fans to regulators on both his bikes after suffering a failure 200 miles from home on a cold wet day on his VFR750 - mind you the aftermarket RR might never fail but can't be too careful, he blames the fairing keeping airflow off the RR..
2016 SV650 AL7
Old 26-08-19, 07:32 PM   #73
Adam Ef
Adam Ef's Avatar
I noticed the two side radiators kicked out a lot of heat very quickly when he started it up today. It was very hot here today and the engine warmed up to 60 degrees in about a minute! I might have to try and get a proper test ride up to speed on one. I'd be looking at it being at motorway and NSL capable / long journey end of the spectrum. Still not sure I'd dare filter on it though, so possibly not a great commuter?
Past:
Old 26-08-19, 07:54 PM   #74
admin
John T
admin's Avatar
Default Re: First world problems and bike dilemmas
It does run hot. The rear cylinders generate heat into the frame and your legs. I used to commute on it but being in the sticks little filtering was needed. I have used it for filtering on traffic snarlups on some of my trips and its no worse than my SV, my mates on GS's have far more trouble with their wide bars and panniers.
Sent from my Nexus 7 using Tapatalk
Old 26-08-19, 07:57 PM   #75
admin
John T
admin's Avatar
Yep, that's a common fix and fitting a non Honda rectifier.
Old 26-08-19, 08:45 PM   #76
Adam Ef
Adam Ef's Avatar
Do you know if it's possible to angle the bars outwards slightly? They felt a bit too pointed inwards on this one but the last one I sat on was fine. Both had standard bars. I had read something about them being fixed at a certain angle with a tab that locks into the fork? The height of them felt fine with a good slight forward lean but not too aggressive. My hands were twisting out sideways slightly though.
Past:
Old 26-08-19, 09:32 PM   #77
admin
John T
admin's Avatar
They do have tabs that lock in. There is a bit of slack for adjustment, you'd get more if you trimmed the tabs or filled then off. I've fitted risers to my bike for a less crouched forward position. See image below
Old 26-08-19, 09:38 PM   #78
Talking Heads
Ah the dreaded central revcounter, hated that about mine, I need to know speed so gimme a big central speedo, I can hear what the engine is doing, I don't need a ruddy great revcounter dominating the dash. Grrrr!!! /endrant
Talking Heads is offline   Reply With Quote
Old 26-08-19, 10:16 PM   #79
Adam Ef
Adam Ef's Avatar
At least the whole dash is positioned centrally. Take note Yamaha!
Cheers for the info John. I think I need to do some more research and visit a dealer.
Past:
Old 26-08-19, 11:54 PM   #80
Talking Heads
Does your 900 tracer have the assymetric dash and fuel cap like the MT-09?
Daft idea.
If you're going to Ye Honda Shoppe, ask them about servicing costs for the VFR.
Make sure you're sitting down first.
world's fast production bike is an electric bike SUPERSTARDJ01 Idle Banter 13 21-05-14 01:27 PM
Bike Channel is now Bike World! SIII Idle Banter 1 12-04-12 08:30 PM
Sexiest Eco bike in the world? Spiderman Idle Banter 17 30-11-09 07:30 AM
Animals of the bike world.. John 675 Photos 62 31-03-09 11:21 PM
Problems with my bike can someone help!!! Muzzy SV Talk, Tuning & Tweaking 2 13-05-06 01:26 PM
