07-03-06, 12:14 PM | #1 |
need fuel tank for '99 SV - will a used one be ok?
I've been having loads of problems with my '99 SV, and it's finally been diagnosed as a kinked drain hose leading to water in the tank.
The garage are saying the only way to fix it is a new fuel tank, at £280 A cheaper 2nd hand one would be great, but is there any way I can find out if it's got the same problem? cross posted on BCF for those who read both sites |
07-03-06, 12:21 PM | #2 | |
Re: need fuel tank for '99 SV - will a used one be ok?
If it is a kinked pipe then it is easily viewable and fixable at the back on the tank just under the drivers seat. I have a spare tank - Y2K blue, but the internal drain pipe has cracked away from the rim of the tank - very difficult to fix properly. |
07-03-06, 01:15 PM | #3 | |
So it was water in the tank then. I reckon they are having you on. The drain hose connects form the underside of the tank and follows the bike down and out underneath the rear brake pedal, next to the clutch cover. Lift your tank up and you'll see water come out fom it. You do not need a new tank, you should be able to find the kink and straighten it out.
07-03-06, 01:29 PM | #4 | ||
07-03-06, 01:40 PM | #5 | |
07-03-06, 08:12 PM | #7 | ||
You will get water in the fuel though, lots of it. The pipe rusts when water sits in it, this is often caused by the overflow hose connected to the end of it getting kinked, this is most likley what the spanner boys have diagnosed. I'm guessing that a breakdown in/lack of communication has led to this thread.
08-03-06, 03:51 PM | #8 |
Mine broke right at the top and fuel was ****ing out under braking until the tank was about 3/4 full - took me a while to work out exactly what it was!
fuel tank | mikey devon | Stuff Wanted | 2 | 05-04-09 10:28 AM |
Fuel tank | svrich | Stuff Wanted | 4 | 30-09-08 07:45 AM |
K2 650 Fuel Tank | Daveh | Bikes - Talk & Issues | 3 | 29-03-08 03:16 PM |
Fuel tank | Mike2165 | SV Talk, Tuning & Tweaking | 8 | 05-11-07 10:17 PM |
the sv fuel tank | kwak zzr | SV Talk, Tuning & Tweaking | 15 | 23-10-07 04:21 PM |
