01-10-14, 11:22 PM | #1 |
Bar end thread? Pointy.
I've got a 2011 pointy and the bar end bolt is doing nothing inside the bar. There is something in there floating about but there is no thread and screw contact as the screw can be pushed straight in after wiggling with this floating thing. I have no idea how the bars actually work but is it a thread insert that has come loose? Either way, does this mean a new clip on or will any expanding screw type bar ends fit as the hole is only just big enough for the screw?
02-10-14, 06:40 AM | #2 |
Re: Bar end thread? Pointy.
There is normally an expanding bolt assemble of some description.
IE several parts that when screwed together ride against and over each other expanding and locking in place. My guess is that the end part which is the only threaded part has slipped into your bar further than the bolt will reach. Take everything out of the tube (you may need to take the clip on off to do this) - put it all back together, semi tighten it and put it back in the bar. Then position and fully tighten. Top tip next time don't unscrew the bolt completely..
Currently driving a Corsa.... Last edited by shiftin_gear98; 02-10-14 at 06:41 AM. |
02-10-14, 09:56 AM | #3 |
I have no idea how it happened as this is how I bought it - with a loose bar end. I just had a look and I can see no way of removing any of the insides.
02-10-14, 11:53 AM | #4 |
Should be internally as shown in link:
http://www.suzukipartshouse.com/oemp...r-with-cowling There should be a long tube around the countersunk screw down to an expanding rubber bung wiht a nut on the back.
SK9 Sport Black Delkevic can. Non arbores caesa suum mittere nuntius, sed magnum numerum electrons uehementissime incommo. |
02-10-14, 05:36 PM | #5 |
Try taking the bolt out of the bar end you have and see if that'll reach the threaded part inside the bar. If it does, wind it in a couple of turns and give it a tug. Will save you having to dismantle the bars to get it out. The threaded bit is mounted inside a rubber grommet and the whole thing expands when you tighten it and grips the inside if the bar. If you just tighten it a bit, it shouuld still be ok to pull out.
That was on a k4 though...
K4 trackbike, a black K8 S loaded with my spares and a 1989 CBR 400 TriArm with all the trimmings. |
02-10-14, 07:43 PM | #6 |
Fixed it cheers guys! Had to give it a fair bit of welly with some pliers and it all fell out. The nut at the very end was floating about.
9/11 Discussion Thread - Split from 9/11 respect thread | Berlin | Idle Banter | 76 | 15-09-12 08:32 AM |
The "question Scoobs' sexuality" thread (aka the real Xma get together) NB: this thread title is extremely long isn't it? | the_lone_wolf | South & West Surfers | 69 | 25-11-10 11:45 AM |
The Racing Thread - THIS THREAD CONTAINS RESULT INFO | Jelster | Racing and Paddock Chat | 1491 | 15-11-06 12:10 AM |
Thread split from St Georges Day rideout thread...rant, etc. | RenamedMonkey | South & West Surfers | 24 | 18-04-05 11:16 AM |
