Old 29-08-08, 11:30 AM   #1
vardypeeps
Default Brake Pistons?
Hello again guys!
I'm planning on servicing my front and rear brakes as the dust seals are set for falling out (due to neglect from a previous owner, muck has got behind them and then pulled them out). I can get hold of rubber grease and the piston seals but am I ok using stainless steel pistons as I'm not sure what the normal ones are made out of?
It's probably a simple answer but all replies are welcome.
Old 29-08-08, 11:53 AM   #2
Grinch
Default Re: Brake Pistons?
I think the normal ones are steel.... are you saying that your going to replace the pistons then?
Old 29-08-08, 11:58 AM   #3
vardypeeps
Yeah seen them quite cheap on that wemoto (are they any good?) and the ones that are in have seen better days. They have scores in the sides and dents on the very rim of the piston.
It is worth me replacing them aint it?
Old 29-08-08, 12:07 PM   #4
Grinch
Never used Wemoto so couldn't say, but if they are scored and you think they need it then its something you can do. Nothing worse then getting all the work done and finding out the pistons that you didn't swap are the reason it will not seal right.
Old 29-08-08, 12:12 PM   #5
Grinch
Just had a look... 22 quid per piston, with seals, so you would need 88 quid for the set.
Seeing as I paid 18 quid per calliper so 36 quid in all just for a piston seals that's not bad.
Best way to clean up brake pistons? curium SV Talk, Tuning & Tweaking 12 06-04-09 09:42 PM
Any QUICK way of getting brake pistons to retract? goof SV Talk, Tuning & Tweaking 8 24-06-06 07:10 PM
scaring on brake pistons huge SV Talk, Tuning & Tweaking 2 13-01-06 04:32 PM
new brake pistons and seals. where from? raymond smith SV Talk, Tuning & Tweaking 2 30-04-05 09:24 PM
Rear Brake Pistons JMCHITTOCK SV Talk, Tuning & Tweaking 8 22-02-05 09:23 AM
