Old 30-04-21, 07:19 PM   #2231
redtrummy
Default Re: What have you tinkered with today?
Bled the front brake after replacing the seals and rubbers, then changed the fluid in the rear brake. (Never been changed since new, bad boy me) Then set about all cable change on my MTB, they were about 25 yrs old. Halfords will change the inners at a bikes first yearly service, why?
redtrummy is offline   Reply With Quote
Old 30-04-21, 08:13 PM   #2232
DJ123
DJ123's Avatar
Probably because if they built it, it'll need doing!
BMW F800ST
Old 30-04-21, 08:31 PM   #2233
Adam Ef
Adam Ef's Avatar
Because they fit their bikes with the cheapest possible non-stainless cables that will have surface corrosion from moisture in the air after a few months and start to seize into the outers after a year or so. They will also replace them with the same sort of cables at the yearly service, so you'll need another service in the future. Saves about £1 max per cable not opting for decent stainless.
At the shop I work at we only fit stainless die drawn slick gear and brake cables.
Past:
Old 30-04-21, 09:04 PM   #2234
redtrummy
Yes have fitted s/s and always do - as you say Adam creating a customer churn. Would not let H. them anywhere near my bikes.
Old 02-05-21, 12:33 PM   #2235
Dave20046
Dave20046's Avatar
Originally Posted by CheGuevara View Post
Day off (extra long weekend) so started prep for Cadwell on Saturday. Oil change, installed the brake guard (turned a spacer in delrin on the lathe - still not perfect but much better fit), new bearings in my front spare/track wheel, supercorsas installed on same set of wheels, disks removed and cleaned up, indicators removed(rears we're badly corroded and broke), headlights taped up.
To be honest I would have done the oil change AFTER the trackday. You've got it extremely hot then cold , then extremely hot etc. etc
No problem, you'll just have to book another one now
Old 02-05-21, 12:39 PM   #2236
CheGuevara
Agreed, though it really needed doing - not many miles in what was in there, but it had been in there a while, and was pretty grim.
- K9 SV650S: Hel brake lines, carbon end can
- SZR660: The project...
- K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now)
CheGuevara is offline   Reply With Quote
Old 02-05-21, 12:43 PM   #2237
Dave20046
Dave20046's Avatar
Ah, in that case yeah you probably don't want to ride hard if it's full of ****/not going to do its job.
Old 03-05-21, 05:49 AM   #2238
Adam Ef
Adam Ef's Avatar
New springs front and rear on the DRZ. In true Suzuki fashion, soon the only remaining original parts will be the engine and chassis!
Past:
Old 03-05-21, 05:59 AM   #2239
Chris_SVS
Chris_SVS's Avatar
The new owner will be very happy you've done all this work
Chris_SVS is offline   Reply With Quote
Old 08-05-21, 08:03 PM   #2240
DJ123
DJ123's Avatar
New front pads on the bike yesterday. Oddly one of the inner pads on 1 side was half the thickness of the other (hence the need for a change). The calliper & pistons are ok, no obvious signs of any underlying issue. I cleaned them up and re-torqued the disc bolts (floating set up) to make sure everything is aligned. Will see how this set go!
Thankfully pads are cheap at only £25 for the set (EBC).
BMW F800ST
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
