ok, so since i dropped the bike the other day, i have had a problem starting it,
when i press the start button, nothing happens, and sometimes to start it i have to shake the bike... eventually it starts but its damn annoying if i stop and have to start again quickly! help!? |
Sounds like a bad connection on the circuit. First place i'd look is the battery, after that takes a little more work but if you can trace the wire you should be ok.
yeah that was kinda my guess too, i hate electrics though
Jake.
Before you destroy the electrics on the bike check the Clutch switch and the side stand switch. Remove the plug from under the clutch lever (look for it, its there) and bridge the 2 terminals of the plug with a paper clip or similar. If its starts better, then its the clutch switch. |
ok cool i'll give it a go thanks
Starting problems | Iansv | Bikes - Talk & Issues | 6 | 02-03-07 01:12 PM |
Starting problems with my Sv 650 K3 | -pATz- | SV Talk, Tuning & Tweaking | 5 | 30-03-06 08:30 PM |
Problems starting | riktherider | SV Talk, Tuning & Tweaking | 4 | 11-06-05 06:13 PM |
Starting problems | squirrel_hunter | SV Talk, Tuning & Tweaking | 2 | 14-05-05 09:37 PM |
Starting problems... | Aaron | SV Talk, Tuning & Tweaking | 9 | 22-12-04 07:45 PM |
