23-09-19, 08:38 PM | #11 | |
Re: Underwater SV
23-09-19, 08:45 PM | #12 |
Re: Underwater SV
I wouldn't have rotated that engine with only having done what you did.
You need to drain all the oil and water from it first as all you've done is pump it round the system. You need to take the carbs off, they need to be drained. You also need to check the inlet tracks for water. You need to drain the engine oil. I would also be tempted to remove the oil gallery plugs as well in case there is any water in there. You need to remove the exhaust and drain that out. And you need to remove the valve covers to ensure there is no water in there. And if you found mud in the speedo, guess where else it is... |
23-09-19, 10:02 PM | #13 |
Re: Underwater SV
sorry to hear this, hope it works out ok for you
2018 SV650AL8 2001 KTM 640 Duke2 2015 KTM 390 Duke |
24-09-19, 07:50 AM | #14 |
Re: Underwater SV
wanted to wash bores out before draining oil/water but suppose I could have done it afterwards. Think its all academic really but will carry to try a start. Even if that works how reliable itll be in the future with corroding contacts etc is anyones guess....
24-09-19, 10:25 AM | #15 |
Re: Underwater SV
I'd start by taking the battery off !
Was: K2 naked in rapid yellow - gone to a better? place Now: Street Triple R |
24-09-19, 03:02 PM | #16 |
Re: Underwater SV
Roll it down a hill and into a wall and claim you fell off?
24-09-19, 05:36 PM | #17 |
Re: Underwater SV
Into a canal?
24-09-19, 07:31 PM | #18 |
Re: Underwater SV
It was in the lounge charging Just about the only good thing! Now the bores are oiled, sump drained, speedo internals cleaned but think Ill have to buy a new oil filter as there looks to be mud in the old one and I didnt want to spend anything on it until it started....
25-09-19, 08:42 PM | #19 |
Junior Member
Re: Underwater SV
OMG, what a nightmare. I hope you can rescue it...as the battery wasn't in the bike, you may have saved the ecu. Good luck sorting it out.
27-09-19, 09:09 PM | #20 |
Re: Underwater SV
well engine spins ok just on the starter solenoid. Ive disconnected, dried and sprayed up all the connectors I can find (although the injector plugs didnt want to come apart possibly as theyve been in the hottest area) so unless anyone can think of anything else I think I'll try a start.....
Underwater bowling... | Specialone | Idle Banter | 15 | 16-09-13 03:47 PM |
underwater camera housing` | Jimmy2Feet | Idle Banter | 14 | 03-04-11 05:14 AM |
Underwater photography | tricky | Idle Banter | 1 | 05-09-06 05:47 PM |
