Old 18-08-19, 10:27 PM   #11
Default Re: Speedo showing random numbers. Speed sensor seems in one piece?
if its a curvy then its 4 pulses. the "rotor" can be ok but the "housing" fubar. this usually happens after a recent tyre change.
no a k5 can be a PITA. you must count the pulses or check your bikes "proper" year of manufacture. usual way to sort of tell is if the clock rev counter is white its 8 pulse if its black then its 4 pulse.
Old 19-08-19, 08:04 AM   #12
Barney626
I'll have a go at counting today, mine has black clocks but after fiddling with it I feel like it has 8 pulses.
Surely the thing that determines the number of pulses is the rotor? Can they not just be switched out as the sensor has a single pickup?
Barney626 is offline   Reply With Quote
Old 19-08-19, 05:27 PM   #13
Barney626
Speedo sensor arrived today. Put the new one in and instantly solved the issue.
Must have been damaged wiring in the pickup sensor
Oh well, problem solved
Old 19-08-19, 06:07 PM   #14
Seeker
Seeker's Avatar
Great news!
Speedo reading random numbers TCochrane SV Talk, Tuning & Tweaking 5 22-05-13 03:57 PM
Pointy cutting out and speedo random numbers. Elliott SV Talk, Tuning & Tweaking 6 10-10-12 03:53 PM
SV650S-K3 Speedo failed (random numbers) - Rotor seems OK, speedo drive problem? Tallguy SV Talk, Tuning & Tweaking 4 25-05-12 12:38 PM
Pointy speedo random numbers? Badeye Bikes - Talk & Issues 19 17-03-12 08:15 PM
Speedo accuracy. If your '99 650 is showing 37mph on the speedo. lloyd_christmas SV Talk, Tuning & Tweaking 14 12-06-08 12:02 PM
