08-09-19, 03:56 PM | #1 |
Junior Member
Burning my cap out
Hello all have a 1st gen curvy on a 2001 plate
Got charging issues and I'm no good with eletrics Bought a multimeter and replaced the battery with a yusa yt12a bs reads 12.7 without engine started as its new when I start the her she jumped straight up 18.4 I presume this is a bad RR and just to replace the entire unit ?? Never seen it before so high and does this indicate its frying it |
08-09-19, 05:08 PM | #2 |
Re: Burning my cap out
Yes will be a duff voltage Regulator as 18+ volts will fry a battery in short order. Somewhere around 14volts a more normal charging rate on 12v electrics.
A quick look on eBay shows new RR units available from around £18 - have to wonder whether they'd be as robust as O.E. but God knows how much a new one from Suzuki would be and a new cheapie probably still a better bet than a typical used item
2018 SV650AL8 2001 KTM 640 Duke2 2015 KTM 390 Duke |
08-09-19, 06:24 PM | #3 | |
Have a read here, https://cx500.000webhostapp.com/Mosf...sfetUniRR.html HTH
08-09-19, 08:23 PM | #4 |
Yes, bad RR.
Get yourself an Eletrex one to replace yours Be aware that curvy's had two types, one had a single connector, the other (probably later ones) had two connectors Mine was a 2002 and had the two connectors https://www.electrexworld.co.uk/cgi-...O&ACTION=Go%21
09-09-19, 07:21 AM | #5 |
Meanwhile dont run it with that sort of charge going into the new battery or you will be buying another one very shortly.
09-09-19, 09:19 AM | #6 |
+10
10-09-19, 04:48 PM | #7 |
When the Reg/Rec packed up on my TDM850 it not only fried the battery, but also blew most of the bulbs and took out the ignition module / ECU before I realised what the problem was
So yeah, isn't much on a 12V electrical system that likes a sustained 18 volts through it
11-09-19, 03:46 PM | #8 |
The cheap Chinese ebay regs are a big gamble and not worth it IMO. Some people have had luck with them, plenty have not and some of the regulators have little but sand inside them.
12-09-19, 05:01 PM | #9 |
If you do fit an Electrex World one you will need to move it to under the pillion seat or wherever you can fit it as bigger than the Suzuki item & tail piece won't fit back on, plus altering the wiring to suit if you have the gear to & can solder. I didn't so returned the Electrex item for a refund and check the original regularly.
'carried away by a Moonlight Shadow. . . ' OOII SHIRLEY!! '99 'curvy' SV650S, R&G Bobbins, Renegade Endcan, no anodised bling. . |
12-09-19, 11:18 PM | #10 |
65 CB160 (67-69), 69 350GTR (69-72), 72 R5, 73 RD350 (73-84), 82 XZ550 Vision (84-03), 01 Concours C10 (03-19), 89 EX250 (11-14), 00 SV650S (14-16), 03 SV650S (19-) |
Burning of the Qur'an. | Daimo | Idle Banter | 80 | 14-09-10 03:56 PM |
Burning oil | yorkie_chris | SV Talk, Tuning & Tweaking | 10 | 02-12-07 05:21 PM |
DVD Burning | gettin2dizzy | Idle Banter | 20 | 03-11-07 05:46 PM |
burning oil | auldyin | SV Talk, Tuning & Tweaking | 4 | 26-07-06 06:05 PM |
Burning too much oil. | Redi_Jedi | SV Talk, Tuning & Tweaking | 22 | 08-02-05 03:53 PM |
