Old 12-09-19, 08:53 PM   #11
SV650rules
Default Re: Chain and Sprocket Compatibility - Pointy 650S L2
One tooth on front sprocket is worth 3 on the rear IMHO one tooth more or less on rear sprocket would hardly be noticeable. Standard naked Gladius and L7 is 15/46 with 112 chain and that makes a really nice ride, max speed limit in UK is 70mph, unless you do a lot of motorway miles use the lower gearing for more pep ( and fun ) on normal roads. The twin spark engines make more power but torque and power shifted up the rev range a bit.
Have you tried chainsandsprockets.co.uk they seem to have a good database ..
2016 SV650 AL7
Old 23-09-19, 07:43 AM   #12
aesmith
They only list a 45 tooth for the L2, however they confirm 108 link chain
I think that since they seem to be the same, even though nobody can actually confirm, I think I'll chance my arm and order a kit described for a K6. Worst case I think would be having to get a different sprocket.
Old 27-10-19, 08:48 AM   #13
aesmith
Well I ended up ordering the kit described as for SV650S K6, in order to get the 44 tooth rear. Now fitted, I couldn't see any indication of incompatibility anywhere. I think they're the same for all faired pointies. Shame that's not documented anywhere.
Standard front sprocket, bigger rear sprocket, how many more links in chain required? Holdup Bikes - Talk & Issues 6 27-02-12 12:40 PM
Pointy SV chain & sprocket fit curvy? nicky-jano SV Talk, Tuning & Tweaking 8 08-04-09 09:53 PM
Front Sprocket compatibility swiest152 SV Talk, Tuning & Tweaking 3 16-03-08 06:45 PM
Riding Position of a Curvy 650s compared with a Pointy 650S Power Crazy SV Talk, Tuning & Tweaking 20 25-04-07 07:18 AM
04 650S chain and sprocket sizes Captain Nemo SV Talk, Tuning & Tweaking 1 28-02-06 09:58 AM
