Old 04-03-10, 12:29 AM   #1
5hort5
Default Ring Terminals - battery connections.
I'm off to get a new battery and an optimate tomorrow due to killing my battery with my latest test ride. Anyway I am going to fit the quick connector for the optimate but this will then mean I have two ring terminals and the main battery lead connected to each terminal of the battery, so:
  • Ring terminals for the Fireblade Reg/Rec
  • Ring terminals for the optimate
  • SV standard battery terminals
Is there a better way of wiring this up or should I just get some longer bolts and cooper grease the lot and bolt it up?
5hort5 is offline   Reply With Quote
Old 04-03-10, 12:33 AM   #2
fastdruid
fastdruid's Avatar
Default Re: Ring Terminals
I've got two sets of ring terminals (heated grips and heated jacket) on the VFR with the standard bolts no problem. Slightly trickier to 'start' the bolt than with nothing on but that's it.
Druid
Old 04-03-10, 12:41 AM   #3
5hort5
yer that's pretty much what I was going to do but then I thought I may want to add heated grips for next year with the new uprated reg/rec as it has the power so then I have three ring terminals and the main battery lead. I suppose I was wondering if there was some nice, funky, battery terminal block out there on the market that makes all this easy to add new things without building and inch high group of ring terminal ends on top of the battery
Old 04-03-10, 12:49 AM   #4
fastdruid
fastdruid's Avatar
I'd have a browse of http://www.vehicle-wiring-products.eu and see if there is anything suitable. Report back if you find anything!
Druid
Old 04-03-10, 04:30 PM   #5
Neeja
Default Re: Ring Terminals - battery connections.
An easy way to do it would be to build a rail.Get a 2in. piece of copper, put a 90 degree twist into it, drill 10mm holes in each end. Bolt one to a battery terminal, and put a bolt through the other with a nut in the other side to hold it in place. Solder the rail-bolt to the copper for better connectivity. Then put as many ring terminals as you want onto the rail-bolt and put another nut on the end to tighten it all up. Just make sure to cover the live-one with some rubber or something just in case...
Old 04-03-10, 04:34 PM   #6
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Aux fusebox from Centech
http://www.centechwire.com/catalog/cycles/ap1.shtml
Mine has 6/7 connectors and can handle up to 60A
Means you only have one set of cables running to the battery so less oppertunity to short out (useful on the ADV where the battery is where the front downpipe runs on an SV)
Also makes changing fuses a doddle, you did fuse the accessories right?
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
O ring vs. X ring drive chains Explained - yet again. df1uk SV Talk, Tuning & Tweaking 19 30-04-15 08:15 PM
Corroded connections Razor SV Talk, Tuning & Tweaking 6 16-08-09 08:03 PM
Chain and Sprockets & X-ring vs o-ring? thor SV Talk, Tuning & Tweaking 38 20-06-09 01:59 PM
"Ring" Battery Charger/Optimiser svdemon Idle Banter 3 16-02-09 06:32 PM
Oil Cooler Connections buckstone SV Talk, Tuning & Tweaking 5 17-03-07 09:33 PM
