Old 12-07-17, 05:36 PM   #1
Default S & N swingarms on pointy
i have always wondered if the N swingarm is longer than the S due to the difference in chain link length. well it must be as a 15t-46t 110 link combination still has loads of play in the chain.
pointy S chain and sprockets are 15t-44t 108 link
pointy N chain and sprockets are 15t-45t 110 link
worn S chain and new sprockets 15t-45t 108 link is around 1/3 on adjustment
new 15t-46t 110 link on the S is around 2/3 on adjustment.
Old 12-07-17, 07:33 PM   #2
Grim-Lock
Grim-Lock's Avatar
Default Re: S & N swingarms on pointy
I believe the K9S> has 15-45 108 certainly my L2 has as standard
Grim-Lock is offline   Reply With Quote
Old 12-07-17, 08:32 PM   #3
Biker Biggles
Biker Biggles's Avatar
The N is 1cm longer on the curvy and I think they continued that with the pointy.Yokes were dropped as well to give slightly different geometry.
Old 18-07-17, 02:47 PM   #4
aesmith
The manual gives a longer wheelbase for the N, 1440mm compared to 1430 for the S.
Old 18-07-17, 05:12 PM   #5
that extra 10mm would explain things.
on a side note, i have gone from a 16t/44t (which is around 3t down on rear from standard) to a 15t/46t (which from the old setup works out at around 5t up on the rear or 2t up from standard) and i must say its a lot better for overtaking and tight twisty single track roads. only trouble is i'm trying to change to 7th gear more on main A roads due to the bike sounding like its revving its titzz off compared to before.
Old 18-07-17, 08:19 PM   #6
Grim-Lock
Grim-Lock's Avatar
I am currently running 14-45 108 on my S and i find it nicer on the road and more enjoyable when having fun in the upper revs.
i love me a bit of noise
Rear brake calliper with axle mount for pointy Sv650 pointy nikon70 For Sale - SV's and SV related items 0 18-04-15 06:11 AM
Frame, yokes, swingarms, shock, dogbones, etc Berlin For Sale - SV's and SV related items 0 24-04-11 08:21 AM
Crash.NET - Pramac get carbon fibre swingarms for Catalunya. NewsBot News 0 10-06-09 02:00 PM
JMC Swingarms Lissa SV Talk, Tuning & Tweaking 15 28-08-07 04:54 PM
single sided swingarms pencil shavings SV Talk, Tuning & Tweaking 20 08-03-06 06:23 PM
