14-02-06, 11:51 AM | #1 |
Swapping the sidelight bulb
How do you swap the sidelight bulb? I've recently upgraded the main headlights, but now need to get a nice whiter light in the sidelight/position light.
I've removed the 2 front screws, and the whole light wobbles - but I can't get it to pop out it's hole! Any hints? |
14-02-06, 11:54 AM | #2 |
Use a pair of pliers to pull on the bulb or the surround as your not gonna use the bulb again
14-02-06, 12:05 PM | #3 | |
14-02-06, 12:16 PM | #4 |
It just pulls out the back on the K3--> as far as I know, you won't needt to take the headligh unit appart, remove it from the fairing or anything, just pull off the rubber at the back of it, and see if it's a pull out or bayonet type (Can check when I get home if needed)
Modern motorcycles are bloody brilliant, enjoy it while we can |
14-02-06, 12:45 PM | #5 | ||
14-02-06, 12:55 PM | #6 |
Knob faced knobster
i always did it very gently with a flat head screw driver
2001 SV650 in shimmerin green, Not broken anymore |
Sidelight holder and bulb for nekkid | yorkie_chris | Stuff Wanted | 1 | 09-04-09 07:12 AM |
sidelight bulb on a c class merc? | kwak zzr | Idle Banter | 4 | 27-08-08 07:10 PM |
what sidelight bulb? (curvy) | weazelz | SV Talk, Tuning & Tweaking | 10 | 18-03-07 10:10 AM |
Sidelight housing | Saint Matt | Stuff Wanted | 0 | 23-08-06 05:01 PM |
Sidelight fuse? | Saracen | SV Talk, Tuning & Tweaking | 4 | 23-11-05 03:31 PM |
