20-12-08, 09:30 AM | #1 |
Slight leakage.....exhaust
Hey all, as some of you may know i fitted a 2 into 2 laser extreme system to my K3 sv650 recently. av done a few miles since fitting it and did a routine tighten/check on everything and i have noticed a slight air leakage at front header pipe. i say slight as ya fingers need to be about 10-15mm away to feel it (it cant be heard) and its only from the top of the pipe not all the way round, so i assumed an angle problem sumwhere
after many hours of un-doing the system, wiggling it around and re-tightening (i even brought another gasket) i can not get rid of the chuffing leakage! is there sum sorta sealant i can put in there since the leak is so minor? any advice from the experts? (apart from scrap the cans lol) any input gratefully recieved! thx in advance Amp |
20-12-08, 09:38 AM | #2 |
Re: Slight leakage.....exhaust
High temperature exhaust sealant. You can get some from halfords. I put it around the the outlet, squash the gasket in there, a little more sealant and then bolt the header pipe on.
20-12-08, 11:42 AM | #3 |
I take it you mean it is leaking from the OEM front header (Laser re-uses OEM front/rear header) as you have bought a new gasket....
Are the header nut/bolts tightened up to the correctly? If yes, then I would recommend getting some liquid gasket (available from car/bike shops). Undo the front header and smear some onto the gasket (top/bottom/outside) and the outer section of the header and then reassemble. Last edited by Dangerous Dave; 20-12-08 at 11:43 AM. Reason: Picture Added |
20-12-08, 02:25 PM | #4 |
I'd ignore it if it's so minor.
20-12-08, 02:35 PM | #5 |
thx for your input guys greatly appreciated!
@ yorkie_chris....... the leak is very minor, would ignoring it and letting it blow a lil not do a bit of harm mebe even in the long-term? |
20-12-08, 02:38 PM | #6 |
You've got the chance of some popping and banging... but the EFI bikes deliberately leak air in on the overrun anyway.
There is the danger of a hot-spot making the hole bigger, but I doubt it will cause a problem. It wouldn't bother me to leave it. Obviously the safe approach is to fix it as BA and dave suggest.
20-12-08, 04:25 PM | #7 |
I have a small leak on the Dullsville. I am just too lazy to be bothered with fixing it.
Slight surging problem | noob-saibot | SV Talk, Tuning & Tweaking | 15 | 19-12-08 06:20 PM |
So I had a slight bump! | KnightRider | Thames Valley | 42 | 31-07-08 06:01 PM |
Slight stutters/Weird looking oil | andyb | SV Talk, Tuning & Tweaking | 6 | 10-10-06 10:07 AM |
Curvy Lowers - Slight Damage | sprocket | For Sale - SV's and SV related items | 0 | 24-11-05 01:23 PM |
Slight Concern... Z | MitchC | SV Talk, Tuning & Tweaking | 11 | 16-04-05 06:33 AM |
