Old 14-05-18, 07:27 AM   #1
Crispy
Default Crankcase breather 'sponge'
I have an 08 model and have ordered a new crankcase filter because the old one is looking pretty sad.
Q: Do I have to soak the new one in motor oil before installing?
Old 14-05-18, 09:00 AM   #2
Craig380
Default Re: Crankcase breather 'sponge'
No need to oil it, it'll get enough oil from the crankcase vapours
Old 14-05-18, 09:20 AM   #3
Crispy
Thanks. Clean the old shriveled one with methylated spirits? (new one is on backorder).
Old 14-05-18, 12:56 PM   #4
Craig380
Just use warm soapy water (washing up liquid or similar), squeeze it gently dry-ish in an old bit of cleanish rag and refit.
It actually doesn't need to be cleaned as such, its purpose is to trap oil droplets coming from the crank breather so that they don't contaminate the air filter element too much. When enough oil is trapped, it will drip back down the breather tubes. You can also just gently squeeze the oil out of it into kitchen paper etc without washing it.
Old 14-05-18, 02:48 PM   #5
R1ffR4ff
R1ffR4ff's Avatar
+10
R1ffR4ff is online now   Reply With Quote
Alternative to the V2 sponge. slark01 Ancillaries 0 20-05-11 10:05 AM
Sponge Brakes? Hardened Rider SV Talk, Tuning & Tweaking 19 10-09-08 08:48 PM
Crankcase breather andyaikido SV Talk, Tuning & Tweaking 2 05-09-06 06:28 PM
Crankcase breather and custom airkits dubno SV Talk, Tuning & Tweaking 5 08-07-06 03:51 PM
Renegade airkit - Crankcase breather hoses. SteveNZ SV Talk, Tuning & Tweaking 8 10-09-05 09:53 PM
