04-04-08, 02:22 AM | #1 |
Is there a way to work out the prospective top speed after increasing/decreasing sprocket sizes?
I'm just curious other than anything else.
04-04-08, 06:54 AM | #2 |
Re: Is there a way to work out the prospective top speed after increasing/decreasing sprocket sizes?
Yes. Why do you want to change?
04-04-08, 07:10 AM | #3 |
I thought it was ride it...
04-04-08, 07:13 AM | #4 |
Or try this - Gearing Commander
04-04-08, 11:19 AM | #5 |
I wrote a little widget specifically for the SV ... I could upload the software or if you are interested in certain sprocket combo, let me know what they are and I'll just post the output ...
You will need to measure the circumferance of your rear tyre (in CM) |
04-04-08, 05:50 PM | #6 |
Remember any calculators are theoretical, SV's won't rev out in top on stock gearing.
04-04-08, 05:58 PM | #7 |
I don't at the moment I'm just curious really in case I do one day. I suppose Silverstone got me thinking that I have a top speed 25 or 30 miles an hour above the top speed I acheived and also it'd make the nasty little chicanes easier to manage and the silly hairpin at Mallory.
P.S. Blue I haven't got an SV. |
04-04-08, 06:02 PM | #8 |
04-04-08, 06:47 PM | #9 |
04-04-08, 06:52 PM | #10 |
For the SV650 the numbers are thus
SV650 Possible configuration 1 General info:- Wheel circumference = 196cm Front Sprocket = 15 teeth Rear Sprocket = 44 teeth RPM selected at save time = 10500 Speeds with above configuration:- Speed in gear1 = 50.88 MPH @ 10500rpm Speed in gear2 = 70.46 MPH @ 10500rpm Speed in gear3 = 90.71 MPH @ 10500rpm Speed in gear4 = 111.35 MPH @ 10500rpm Speed in gear5 = 130.22 MPH @ 10500rpm Speed in gear6 = 147.03 MPH @ 10500rpm SV650 Possible configuration 2 General info:- Wheel circumference = 196cm Front Sprocket = 14 teeth Rear Sprocket = 45 teeth RPM selected at save time = 10500 Speeds with above configuration:- Speed in gear1 = 46.43 MPH @ 10500rpm Speed in gear2 = 64.30 MPH @ 10500rpm Speed in gear3 = 82.78 MPH @ 10500rpm Speed in gear4 = 101.62 MPH @ 10500rpm Speed in gear5 = 118.84 MPH @ 10500rpm Speed in gear6 = 134.18 MPH @ 10500rpm |
How do average speed cameras work? | Magnum | Bikes - Talk & Issues | 50 | 24-04-09 09:51 PM |
sprocket sizes? | hovis | SV Talk, Tuning & Tweaking | 12 | 22-01-07 05:40 PM |
Sprocket Sizes | Sideshow#36 | SV Talk, Tuning & Tweaking | 7 | 11-12-06 12:28 PM |
sprocket sizes | antony | SV Talk, Tuning & Tweaking | 15 | 07-07-06 11:49 AM |
04 650S chain and sprocket sizes | Captain Nemo | SV Talk, Tuning & Tweaking | 1 | 28-02-06 09:58 AM |
