Old 28-04-12, 07:53 PM   #1
muzikill
muzikill's Avatar
Default SV pointy throttle body vacuum hose extension.
Thanks to bibio for the kit to do this. heres how it looks...
I'll be using the old spring clips that held the old caps on, they needed stretched to make them smaller as the new hose was a slightly smaller diameter.
so, tank propped up, air filter housing removed, throttle body removed and tops of the engine plugged to stop anything from dropping in, rear throttle body vacuum pipe end ready for fitting... and fitted new hose. Front throttle body prepped...
Done.
Engine inlet rags removed, throttle body re-fitted, air filter housing re-fitted. Throttle body extension hoses routed out. Current balance shown... yeah its out.
After much revving, adjusting, holding the revs, adjusting, revving, adjusting etc..... it was balanced.
Things to note:
*The adjuster screw is made of cheese (possible mod)
*It takes next to nothing to turn the screw and for it to be in/out.
Extender kit tidied away until the next time and for the the tank to be refitted.
Old 28-04-12, 08:08 PM   #2
Default Re: SV pointy throttle body vacuum hose extension
Must get round to doing this to mine
Good pics
Old 28-04-12, 08:31 PM   #3
muzikill
muzikill's Avatar
Good pics
Glad its done now. Its a pig of a job upsetting and taking all that stuff off just to do something that takes a short time. I dont like moving that stuff around. If it aint broke and all that...
Old 28-04-12, 10:14 PM   #4
nice one m8. glad you liked them. it'll make doing a balance a lot easier in the future.
Old 28-04-12, 10:36 PM   #5
muzikill
muzikill's Avatar
Ta bud. I wasnt sure about the hole drilling to store them so I figured the tiewrap was the next best thing.
Old 28-04-12, 10:42 PM   #6
which ever is easier for you. i just drilled a hole on top of the air box and used the well nut that way it's right in front of my face when i lift the tank
i might get a pic when i have the tank up next.
Old 29-04-12, 09:35 AM   #7
muzikill
muzikill's Avatar
Just been out, what a difference. Night and day. Dodgy gear changes, general jumpiness. Gone.
After knowing what the bike sounds like before and after it would be easy to spot. A big pat on the back to those who can do this by ear btw.
Old 30-04-12, 10:41 AM   #8
The Flame
Default Re: SV pointy throttle body vacuum hose extension.
Biblio would you be so nice to assemble a set to be sold and shipped to the City...? I'd really need to rebalance the throttle body but i never have time to take all the measures and go finding the right parts...... thanks!
Old 30-04-12, 12:35 PM   #9
i see no reason why not. you will still need a vacuum gauge to do the actual balancing. these are only an extension to make balancing easier in future.
one more thing. you cannot balance the TB's on twin spark bikes e.g. 2007 onwards without an OBD tool as you need to shut off the auto idle.
Old 30-04-12, 01:37 PM   #10
Nobbylad
Nobbylad's Avatar
Lance - how much for one of these for me also (you could post it out with the adjuster plates)?
As you know, I have an OBD tool, but I still don't understand why you can't just disconnect the ISC (unless the ECU requires some signal from it even when it's shut-off)
pointy 650 throttle body f/s jimathyy For Sale - SV's and SV related items 0 29-02-12 04:47 PM
Scottoiler - which vacuum hose noob-saibot SV Talk, Tuning & Tweaking 2 11-09-09 02:05 PM
What have i done (Snapped Vacuum Hose) TheShadow Bikes - Talk & Issues 12 28-10-08 02:04 PM
Throttle body synchronisation K3 muzikill SV Talk, Tuning & Tweaking 23 23-01-08 06:35 PM
DR posing as an SV - Fuel vacuum hose? MeridiaNx SV Talk, Tuning & Tweaking 10 14-11-07 09:00 PM
