Old 05-05-14, 01:30 PM   #1
electricheadx
Default Powder coating engine casing? Pointy.
I'm about to do some powder coating on my K3. I will be having the engine casings coated, so i just want to check if i need to have the oil sight glass removed before i send it to the coaters.
Denis.
electricheadx is offline   Reply With Quote
Old 05-05-14, 01:34 PM   #2
Default Re: Powder Coating Engine Casing
best to check with the powder coater.
Old 05-05-14, 02:41 PM   #3
squirrel_hunter
squirrel_hunter's Avatar
Yes you will have to remove it.
If you don't they will. Basically I doubt it will survive the heat and even if it did it wouldn't make the finish up to the line very good as it will have to be masked off. This is what I did when I had my TZR covers powdercoated.
Also a good blade is required to trim off the edges once you get the covers back or they will not seal properly. The coater should give you some details on what to do post covering etc.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 05-05-14, 02:44 PM   #4
electricheadx
Cool. Just popped It out with a bit of heat and a socket. Thanks for the help guys.
Sent from my GT-N7100 using Tapatalk 4
Repainting Pointy engine casing? clarke135 SV Talk, Tuning & Tweaking 8 28-08-13 08:12 AM
powder coating FG1 Idle Banter 17 13-01-09 09:43 PM
Powder Coating tactcom7 SV Talk, Tuning & Tweaking 14 03-10-07 11:59 PM
Pointy R/H engine casing and the curveys svrash SV Talk, Tuning & Tweaking 1 11-02-07 08:07 PM
powder coating weazelz SV Talk, Tuning & Tweaking 6 02-10-06 10:57 PM
