19-05-08, 08:18 PM | #1 |
Indicator Problem & fitting front fork seals
Hi all
Am new to this and keen to learn all about bike maintenance so will no doubt have loads of questions! I have bought an 650 sk5 as my first bike and have noticed that it has developed a problem with the indicators. When I switch on the ignition, I can indicate right no problem, cancel that and indicate left, it seems to kill the indicators. The display briefly flashes but no indicator flashing and then I can't even indicate right unless I kill it off and switch on the ignition again. I have had a quick look at all cables but can't see any loose/chaffed connections having replaced my battery recently. Any thoughts? Also, I need to replace the leaking fork seals, anyone have any step by step guides out there? MTIA Dan |
19-05-08, 08:57 PM | #2 |
Re: Indicator Problem & fitting front fork seals
the indicator problem could maby be witht eh switch gear if you say you have checked all wires and conections etc...
19-05-08, 09:01 PM | #3 |
Do your hazards work OK?
20-05-08, 07:22 AM | #4 |
Check your hazards (as stated above). If they work, the fault is in the indicator switch (as the hazards is a seperate switch). If they don't work, chances are the fault is the indicator relay.
23-05-08, 09:03 PM | #5 |
Have checked the hazards and they also kill all indicators, so guess it's a problem with the relay. How do I go about sorting that?
Cheers |
Poping front fork seals | Dicky Ticker | Bikes - Talk & Issues | 5 | 12-06-08 04:02 PM |
Indicator Problem & fitting front fork seals | dannyboy81 | Bikes - Talk & Issues | 0 | 19-05-08 08:44 PM |
Fork Seals | chris8886 | SV Talk, Tuning & Tweaking | 2 | 04-02-08 09:04 PM |
Fitting replacement standard front indicator | richbeales | SV Talk, Tuning & Tweaking | 5 | 21-04-06 07:57 PM |
Fitting an SV1000 front indicator on an SV650? | SVeeedy Gonzales | SV Talk, Tuning & Tweaking | 2 | 03-01-06 10:06 AM |
