Old 26-06-10, 12:01 PM   #1
Gary C
Default Accessing SV spark plugs?
Does anyone else have trouble getting to their spark plugs? I have done it as it says in manual, but i cant get the plug lead off the front cylinder. I managed to get lead off the back cylinder, but cant tell if i have plug socket on the plug to start undoing it. HELP!!!!!!
Old 26-06-10, 12:08 PM   #2
Default Re: SV spark plugs
Are you using the plug tool from the toolkit?
rear is easy, front is a pain.
Be careful with the front as they can get seized
You will get the front lead off, have you taken the bottom bolt off the raidiator to swing it out of the way?
Old 26-06-10, 12:47 PM   #3
Gary C
I am using the plug tool from the toolkit, but i am finding it hard to tell if it is on the plug or not.I have swung radiator out of way. Oh well just have to soldier on.
Old 26-06-10, 05:13 PM   #4
Unfortunately the only way
Old 26-06-10, 08:06 PM   #5
Razor
i use the socket from my 3/8" socket set, better than the toolkit one
Old 28-06-10, 06:11 PM   #6
kd80
Default Re: Accessing SV spark plugs?
Have you put a block of wood between the radiator and the engine? It partially helps with not having to keep moving the radiator.
I'm not sure about you, but I found that my radiator didn't swing much after removing the lower bolt :-/. Once you get the socket in there, swivel it around a little until feel it "click" into place. Then you know the socket is in place. Then keep turning. Probably the best advice . It doesn't help with the fact you're unable to see bugger all!
Best of luck
Old 28-06-10, 06:40 PM   #7
Razor
you can also shoot wd40 up your drain hole...
ohhh matron
Old 29-06-10, 09:20 AM   #8
bigchris
I had to completley remove the radiator, was much easier after that, handy to do it this way if your coolant needs changing,
Old 11-08-10, 09:52 PM   #9
Sly
I couldn't get my front plug off with the tool-kit wrench - it had been done up too tight by a bike shop mechanic - I could tell that I was going to round off the end of the tool-kit wrench with my tool-kit 12mm spanner before it would undo. So, I used the 10mm plug socket from my cheap socket set. Problem was that the socket (standard 10mm plug socket) isn't long enough to appear above the level of the top of the cylinder head without an extender, and when I tried to pull it out, the extender disconnected from the socket, leaving both socket and sparkplug in the hole. I eventually managed to get it out, by using another extender with a tighter fit into the socket, but am now looking for an extended 10mm plug socket - anyone know of a good place to get one? I guess the alternative would be to weld a short extender on the back of a standard 10mm plug socket, but I'd rather get a proper tool for the job.
I made sure to replace the plug using the tool-kit wrench so it wasn't done up too tight for the same tool to remove next time. It's good to know I can get the damned thing out but disconcerting to think that I'd not have managed if I'd had to do it at the roadside, without access to my full toolbox.
If anyone can suggest a supplier for an extra-long 10mm plug socket I'd be grateful.
Old 12-08-10, 12:12 PM   #10
alfa.rbt
^^^ there you go
click
click
click
Spark plugs PAGAN1001 Bikes - Talk & Issues 2 24-01-10 08:39 AM
Which spark plugs to get? gerrymcghee SV Talk, Tuning & Tweaking 22 30-10-09 10:30 PM
spark plugs daddy_sperm SV Talk, Tuning & Tweaking 12 01-03-06 06:12 AM
Accessing spark plugs youdaman SV Talk, Tuning & Tweaking 5 16-02-05 08:53 PM
spark plugs weegaz22 SV Talk, Tuning & Tweaking 4 04-08-03 05:04 PM
