18-01-17, 11:47 AM | #1 |
Pointy idle issue
I have a 2005 pointy and it idles at about 1K sometimes lower, every now and then when i close the throttle after revving it it'll cut out. Is this as simple as adjusting the cables or do i need to adjust the idle as well? And how would i go about doing that on a pointy?
Thanks! |
18-01-17, 11:48 AM | #2 |
Re: Pointy idle issue
I had a curvy that idled at about 1.3K so im assuming these should be the same?
Sent from my iPhone using Tapatalk |
18-01-17, 12:44 PM | #3 |
I'd try adjusting the idle first. Off the top of my head it should be between 1200 and 1400 when measured with the engine warmed up. Adjustment is via a little screw on the left hand side, just under the tank.
in fact ... here ...http://www.cyclepedia.com/manuals/on...ne-idle-speed/ |
18-01-17, 12:53 PM | #4 |
Awesome thanks yokohama! Best get my gloves and safety goggles out then.... haha
Fast idle issue | tom_e | SV Talk, Tuning & Tweaking | 12 | 18-07-16 10:42 AM |
Weird idle/throttle issue | ClunkintheUK | SV Talk, Tuning & Tweaking | 3 | 09-11-15 08:22 AM |
Idle issue. Curvy | Aligowers | SV Talk, Tuning & Tweaking | 18 | 11-06-14 07:51 AM |
speed four idle issue | AndyBrad | Bikes - Talk & Issues | 11 | 16-04-12 07:04 PM |
Honda CG idle issue | Neeja | Bikes - Talk & Issues | 7 | 21-04-09 09:49 AM |
