24-09-17, 10:48 PM | #11 | |
Re: Halfords Coolant advice pls.
if you know that you are going to lay the bike up for any extended time then disconnect the spark plug caps and crank the engine over a few times each week preferably with fresh oil change. when you know you are going to use it then just connect the plug caps again. |
25-09-17, 09:58 AM | #12 |
Get modern.Go OAT
Raisin cookies that look like chocolate chip cookies are the reason I have trust issues. |
25-09-17, 11:54 AM | #13 |
27-09-17, 10:04 AM | #14 |
Agreed, OAT has been around for quite a few years now and is responsible for the 10 year life of antifreeze. The ethylene glycol bit that stops freezing only degrades slowly over time in any coolant, it is the anticorrosion additives (the OAT bit) that is the big improvement as it is much more stable and long lasting. Silicate antifreeze is only required with older systems containing copper and 'yellow metals' and will damage pump seals in more modern (post 1998 iirc) engines. OAT does not contain silicate and is safe for modern aluminium engines and radiators.
I would happily leave OAT coolant my bike for 5 years. Don't worry about colour of coolant, it is only put in to show any leaks and for health and safety reasons because coolant would be colourless otherwise.
2016 SV650 AL7 Courage is resistance to fear, mastery of fear, not absence of fear - Mark Twain Last edited by SV650rules; 27-09-17 at 10:07 AM. |
29-09-17, 10:17 AM | #15 |
Coolant successfully changed out yesterday. I was surprised how clean it actually looked and very quickly flushed through to clear water with no sludge or signs of anything bad. I did a proper coolant flush too just because I'd bought a tin of Wynn's coolant flush just in case so thought I may as well do it for the £6 it cost.
Fairly straight forward job. Just a bit time consuming. My only top tip would be to put the bucket / tub you're collecting the coolant into about a foot further from the bike than you think you should as the coolant does start coming out quicker than you expect when the bolt is first removed even with the rad cap still loosely in place! Oil is later on today if I get time : ) |
29-09-17, 10:45 AM | #16 |
When I last changed coolant on bike and car I used one of my wifes kitchen measuring jugs (don't tell her or I am in big trouble - I got my own set from Aldi now which live in the garage) to measure how much came out, so I knew how much I should expect to go back in, and if I had airlock etc.
29-09-17, 12:40 PM | #17 |
I managed to fit almost all of a 2L container of coolant in and manual states 1.7L, so guessing it went in ok. I did burp the pipes and shook from side to side etc and it needed topping up after that, so hopfeully got any air out. Will check again after the next few rides.
29-09-17, 12:44 PM | #18 |
I think you will be fine.The SV's cooling system is superb,if as you have done,change the coolant when recommended.
Whilst I was trucking about on the Halfraud's site I found this that might be useful, http://www.halfords.com/motoring/eng...eze-tester-meg £1.99
20% off at Halfords... | yokohama | Bikes - Talk & Issues | 0 | 20-03-16 08:23 PM |
Halfords come out top... | DJFridge | Idle Banter | 10 | 21-05-12 09:10 PM |
Halfords | slark01 | Idle Banter | 9 | 21-01-11 03:36 PM |
Halfords Pro 3 For 2 | squirrel_hunter | Idle Banter | 3 | 30-08-09 12:52 PM |
Halfords | Rider | SV Talk, Tuning & Tweaking | 2 | 18-02-05 02:53 PM |
