Old 25-09-17, 07:27 AM   #11
Strangwooduk
Strangwooduk's Avatar
Default Re: Battery or reg/rec
bike started fine this morning
going to replace both battery and reg rec
the reg seems to be putting out low and the battery seems to drop by itself
2 things to create one big problem
Battery
Reg/Rec Kit
First time on V-Twin - Never looked back
Gen 1 Curvy 1999
Strangwooduk is offline   Reply With Quote
Old 25-09-17, 09:26 AM   #12
Craigg
no way that is a genuine FH020AA, it will be some Chinese crap that will just destroy your stator.
buy it from a reliable source. i just got an SH847 for my VFR from http://roadstercycle.com/ comes highly recommended on the VFR forums.
alternatively you could go to Suzuki direct and buy it, its fitted to the vstrom 1000. if you want an FH020AA then I'm sure they are fitted to the last generation R1
Craigg is offline   Reply With Quote
Old 25-09-17, 10:37 AM   #13
Strangwooduk
So which one should I acctually buy ? Been offered a fh010aa for about 30 quid wouldn't that be okay came from a kawi
Sent from my ONEPLUS A3003 using Tapatalk
Gen 1 Curvy 1999
Old 25-09-17, 11:49 AM   #14
Strangwooduk
Bought one
Gen 1 Curvy 1999
Old 03-10-17, 09:03 AM   #15
Strangwooduk
Update for a time who wants to know
Changed the rec to a zx10 one
All is now well !!
Gen 1 Curvy 1999
Old 04-10-17, 08:21 AM   #16
R1ffR4ff
R1ffR4ff's Avatar
All is now well !!
Was it a direct replacement or did you have to hack any wiring?
Old 04-10-17, 08:43 AM   #17
Strangwooduk
Did a little bit of chopping
Extended the stator wires but that was it
Works amazing
Gen 1 Curvy 1999
Old 04-10-17, 08:45 AM   #18
R1ffR4ff
R1ffR4ff's Avatar
Works amazing
How did you extend the wires and affix the plug/s?Don't suppose you took any pictures?
Old 04-10-17, 08:50 AM   #19
Strangwooduk
I shall take some photos when I get home if the weather is okay
Gen 1 Curvy 1999
Old 04-10-17, 08:52 AM   #20
Strangwooduk
I extended the wires with crimps and used insulted spade terminals to connect to the rectifier
Gen 1 Curvy 1999
Can a loose battery terminal prevent the battery from charging while being able to crank the engine? maxinc Bikes - Talk & Issues 5 22-07-11 02:59 PM
dead battery - possible reg/rec + battery? collis SV Talk, Tuning & Tweaking 8 20-09-10 02:47 PM
Optimate battery charger drains the battery flymo Bikes - Talk & Issues 10 10-06-09 10:41 AM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
