03-10-17, 12:44 PM | #1 |
Starter relay issues
Hey guys having an issue with my curvey, bike has sat for a while i started it and heard an odd noise, dam starter still turning , I hit killswitch and still turning put key in off position and key out still turning had to leg it to the shed get tools and disconnect the battery, Figured the relay fused or something and replaced it not long after same again, What you guys think ?
03-10-17, 06:33 PM | #2 |
Re: Starter relay issues
Sorry i noticed its in wrong section ,sorry admin, Anyone got any ideas
04-10-17, 08:05 AM | #3 |
Clearly it's possessed. Get your nearest Catholic priest to perform an exorcism asap.
Sorry no help but free bump If it's not the relay, then there must be a short across it. If you disconnect the battery and reconnect it, does it stop? This would be latching behaviour and could mean a short from the switched power side of the relay to the input. Do you have a circuit diagram?
Silver SV650SK3, Fuel exhaust |
04-10-17, 11:41 AM | #4 |
it keeps going. I was talking to a mate who is a motorbike elec wizz, he thinks its the alarm fitted
04-10-17, 04:16 PM | #5 |
Did I read correctly that you have fitted a replacement relay and still have same problem ? Is anything burnt and shorted on socket that starting relay plugs into ?
If it is same relay re-fitted it sounds like starter relay contacts have welded together, could have badly oxidized while bike standing unused and then when they closed and passed power the heat of bad contact resistance overheated them.
2016 SV650 AL7 Courage is resistance to fear, mastery of fear, not absence of fear - Mark Twain Last edited by SV650rules; 04-10-17 at 04:21 PM. |
04-10-17, 05:38 PM | #6 | |
Do I need to buy a new starter relay? | Doctor Kebab | SV Talk, Tuning & Tweaking | 2 | 27-02-12 09:29 PM |
Starter Relay, Starter Relay connector, Rear cush drive rubbers. | yorkie_chris | Stuff Wanted | 4 | 08-07-11 09:32 PM |
Electrical Issues - Starter Relay Problem? | cornflakes | Bikes - Talk & Issues | 7 | 11-02-10 11:49 AM |
Starter Relay. | Grinch | Stuff Wanted | 1 | 12-03-07 07:20 PM |
starter relay | anna | SV Talk, Tuning & Tweaking | 2 | 14-11-05 02:10 PM |
