16-07-10, 11:49 PM | #1 |
Filling brake system from dry?
I'm rebuilding the rear caliper on my project SV as it was in a pretty poor state with a stuck piston. Also got new SRAD 4 pots for the front. I was going to rebuild them too then saw the price of two sets of seals and they suddenly looked OK.
I've replaced fluid before but never had to bleed a dry system. I need new bleeding kit anyway so which way would you go? Normal one way valve stuff or syringe it in from the bottom (which I've never tried)? Any pointers appreciated. |
16-07-10, 11:53 PM | #2 |
Re: Dry brake bleeding
A rubber tube and a spanner.
17-07-10, 12:05 AM | #3 |
I was just thinking I couldn't be bothered with all that tightening and slackening of the bleed nipple.
I think I must be getting lazy in my old age - I've had a word with myself. So no more difficult bleeding from dry then? That would be nice. I thought the syringe method's got "face full of brake fluid" written all over it. |
17-07-10, 07:55 AM | #4 |
Rubber tube over the nipple/slightly open and the discharge end of the tube blocked with a bolt and a small slit in the side submerged in brakefluid in a clear jar.Pump away till your heart is content and all air is displaced--------lock off nipple---Simples
No mess,drips,spills or fluid in your eye The old ways are sometimes the best |
17-07-10, 08:53 AM | #5 |
I got a vacuum bleeder that I hook up to the compressor, works a treat.
attach to bleed nipple, press the nozzle, and crank the nipple. A couple of pulls on the brake lever and the system is full. I know you can also get hand operated vacuum pumps. Mityvac I think they are called.
Not Grumpy, opinionated. |
17-07-10, 03:18 PM | #6 |
Re: Filling brake system from dry?
syringe it up from the bottom, easy peasey
17-07-10, 03:58 PM | #7 |
open the bleed valves and fill it, as most air will be displaced resultantly
then bleed it as normal. remember that there is two bleeds on the rear
18-07-10, 03:09 PM | #8 | |
18-07-10, 03:33 PM | #9 |
APRILIA back brake------------do they have a problem?
18-07-10, 04:17 PM | #10 |
front brake system | DANINPLYMOUTH | For Sale - SV's and SV related items | 26 | 06-11-09 06:53 PM |
Empty brake system | lazymanc | SV Talk, Tuning & Tweaking | 12 | 10-04-09 05:40 PM |
Total loss electrical system - Can I fit a brake light? | DarrenSV650S | Bikes - Talk & Issues | 7 | 07-07-08 09:38 PM |
gggrrrr, brakes - how would air in the system affect brake ? | Warren | SV Talk, Tuning & Tweaking | 12 | 20-06-06 08:30 AM |
Filling up... | SVeeedy Gonzales | SV Talk, Tuning & Tweaking | 30 | 10-03-05 09:57 AM |
