Old 06-10-07, 04:42 PM   #1
John 675
Exclamation Almost 11.000 miles
I got my bike at three thousend,
wrote it off at four thousend
fixed it and full service a seven thousend
Im just aproaching 11 thousend now
so question is what would you recommend i have serviced/changed?
would the brake lines need changing? as they are still stock?
valve clearence?
i dont know so any info would be usefull
Old 06-10-07, 04:59 PM   #2
barmy.biker
Default Re: Almost 11.000 miles
how olds the bike? my manual says replace every 4 years
valve clearence?
manual says this is done at 14500 miles
Old 06-10-07, 05:06 PM   #3
John 675
Exclamation Re: Almost 11.000 miles
valve clearence?
thats fair enough then... i wasnt too sure when it was all due,
so its just another oil and filter and possibly an air filter ( i wanted a K&N for a while anyway )
what else would be a good idea to look at
its a K5.
Old 06-10-07, 05:26 PM   #4
I woudn't bother replacing the brake hoses with stock.
HEL or similar braided ones are way better and likely cheaper than the rubbber crap.
Also HEL are lifetime guaranteed, so no more replacements
Old 06-10-07, 05:29 PM   #5
John 675
Now that is good to know, do you see any performance inrease?
Old 06-10-07, 05:31 PM   #6
barmy.biker
its just oil & filter , air filter and inspect clean tighten adjust if things need doing
Old 06-10-07, 08:55 PM   #7
Doesn't make any difference at all to the total braking power, that can only be done by bigger calipers/smaller master cylinder/hard pads, what it does do is give you a harder lever and loads more feel in it.
How much difference you notice will depend on how worn your originals are, but nobodys complained yet.
If you don't want to change then I'd change the fluid at least, changed the fluid on some older cars and whats come out has been some 'orrible gunge nothing like proper fluid lol
Old 07-10-07, 07:39 PM   #8
SVeeedy Gonzales
11000 is the first official filter change since the 600 miler (though many change it before then) and the normal checks.
I've not bothered with fluid changes (meant to change after 2 years but it's a k4 and all works fine so far) and will probably leave those until next year and get chain/sprockets/braided lines/fluids all done at the same time. Or maybe 2009...
RIP Miles MiniMatt South & West Surfers 0 31-03-08 10:35 AM
3K Miles on a new SV! colinbal4 SV Ecosse 4 19-07-06 01:46 PM
How many Miles Jack SV Talk, Tuning & Tweaking 7 25-02-06 02:18 PM
20 miles too few Caddy2000 SV Talk, Tuning & Tweaking 15 11-01-06 06:19 PM
50,000 Miles and still going Mags SV Talk, Tuning & Tweaking 18 23-12-05 01:36 PM
