Old 26-03-08, 07:44 PM   #11
andyaikido
Default Re: Engine braking... any hazzards engine wise?
Originally Posted by pencil shavings View Post
I was told that engine breakig on my RS125 might have contributed to the top end going, any truth in this? I was warmed up and ridden in the powerband all the time, only way to ride it!
There might be something in this.
No throttle means no lubrication. I don't think it would matter though unless you were engine braking for a very long time, like dowm a very long hill.
Any 2 stroke experts on here?
Old 26-03-08, 07:48 PM   #12
So long as you downshift smoothly then there's not a problem, why would it wear the clutch out, if the engines slowing you down then the clutch is engaged.
Just don't crunch through the box like a monkey, it should slip in when you blip it to the right revs
Also a 2 stroke still has lube at idle, if it's got an injector pump then it'll still feed it oil.
Old 26-03-08, 07:51 PM   #13
Razor
I often see monkeys riding bikes like this. They should stick to things they know about, like peanuts and PG tips ad work...
Old 26-03-08, 10:38 PM   #14
pencil shavings
haha
Old 27-03-08, 07:44 AM   #15
arenalife
RE the RS125, yes. It's not recommended to coast on the over run on 2 strokes as there's no lubrication for the mains and bore. Manufacturers advise keeping the throttle open partway.
Old 27-03-08, 09:05 AM   #16
flymo
flymo's Avatar
there is a problem with this. If you down shift too early to the point that the engine revs very high then you can cause serious damage. Remember that the rev limiter only works by inhibiting ignition and so offers no protection at all if the engine is mechanically driven too fast by the back wheel.
Provided that you keep the revs within a sensible limit doing this then you should be fine. I have seen a bike on track spew its guts out as a result of very high revs in a downshift though.
Old 27-03-08, 12:35 PM   #17
Dangerous Dave
No truth in that.
Old 27-03-08, 12:41 PM   #18
tranx
Originally Posted by glang View Post
The only thing I was told is that using engine braking wears the clutch/chain/gearbox more and as its easier n cheaper to replace brakepads its better to use the latter. Makes sense dont it.
There's very little extra wear on the chain and no extra wear on the engine/clutch/gearbox. You wouldn't notice a single penny of savings by not using engine breaking.
Old 27-03-08, 06:55 PM   #19
TOLAROS
TOLAROS's Avatar
It is true
...and as its easier n cheaper to replace brakepads its better to use the latter. Makes sense dont it.
Partially true,but as long as you keep downshifting at a reasonable rate(not easy,it feels great!!) and as long as you don't cause overreving due to downshifting,you will never replace an engine part because of wear/damage caused from downshifting
TOLAROS is offline   Reply With Quote
Old 27-03-08, 07:46 PM   #20
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Just keep an eye out for Sheriff Rosco Coltrane...
Other than that you should be fine
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Engine Breaking? Hopefully not. Engine braking - is that OK? butterick99 SV Talk, Tuning & Tweaking 14 12-09-09 10:31 PM
Engine braking Lakes_Puma SV Talk, Tuning & Tweaking 18 02-06-07 02:30 PM
engine braking on the sv! kwak zzr SV Talk, Tuning & Tweaking 11 25-04-06 12:01 PM
Braking an engine svrash For Sale - SV's and SV related items 1 22-03-06 10:43 AM
Engine braking curium Bikes - Talk & Issues 21 29-03-05 04:52 AM
